Need low pressure shutoff switch
andrew schultz
Illinois
Hello all,
I am new to owning a home with a well system. It is a sandpoint well. I am looking to replace my shallow well jet pump (3/4 hp) teel pump with probably a Gould JRS7 pump. Current pump is 15 years old and has to run for up to an hour to fill the pressure tank to 56psi.
I have some concerns that my well runs low of water and that it will not be able to keep up with a strong running pump. A little more background on the system. Between the pump outlet and the pressure tank there is an iron filtration system.
In my mind I need the typical square d 30-50 psi pressure switch between the tank and the iron filter. I would also like to put in a low pressure shutoff switch to stop the pump if the water supply runs low (between the pump outlet and the filtration system). Does this sound like the right setup to ensure the pump is turning on and off based on pressure tank pressure and that if water supply runs low my pump will shutoff?
Is there such a low pressure shutoff switch available somewhere? My internet searching has come up empty.
thanks
Andy
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
The low pressure switch you want is called an FSG2-M4. But it will only shut the pump off if the pressure drops to 20 or so. That means a faucet has to be open when the well pumps dry, or the pressure will just hang like it did for an hour trying to fill to 56, and the pump won't shut off. You need something like the Cycle Sensor that doesn't rely on pressure to protect the pump from running dry. The Cycle Senor looks at amps and knows when the well is dry, no matter what the pressure is at that time.
