Need Help With Sprinkler System
Discussion in 'Irrigation / Sprinkler Forum' started by SUE2, Aug 12, 2006.
  1. SUE2
    SUE2 New Member
    Aug 12, 2006
    I Need Help With A Sprinkler System. I Have A Six Zone Automatic Sprinkler System And Only One Zone Is Coming On Over And Over Again. The Indexing Valve Is Also Leaking. What Should I Check And How Can I Fix It? Thank You
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Are the other 5 zones programmed to operate for a period of time? It sounds to me like you need to program the system properly. I don't know what an "indexing valve" is, but if it's leaking, it needs to be repaired or replaced. Also, save some enegry when typing. Just use upper case for the first word in a sentence and proper nouns.
  4. SUE2
    SUE2 New Member
    Aug 12, 2006
    All the zones are set to come on for 15 min. then off for 15 min. on automatic. The system also has a munaul setting and when I turn it to manual the same zone keeps coming on all the time. I do not know what makes the system change zones.
  5. Gary Swart
    Sep 1, 2004
    Yakima WA
    When operating in the automatic mode, zone 1 will start at the time you has set as a starting time. It will operate for the length of time you has specified for it to run, then it will turn off and zone 2 will start and run for the length of time specified for it and so on. Usually in the manuel mode, zone 1 will come on when the start button is pushed and the system will continue through the cycles just like in the automatic mode. Perhaps your controller required you to manually advance the zones when in the manual mode. Try leaving the controller in the automatic mode, but manually starting the system.
  6. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    You said you have an indexing valve. If it is what I think it is, you only need a timer to turn on the pump or whatever water supply you have and this valve jumps to the next zone. It is a contraption that sits on top of 7 pipes in your case. The center one feeds the valve water and the other six are the zones. Five holes are plugged at all times and when the water is turned off and on again, the index valve jumps to the next zone and keeps repeating itself.
    bob...
Similar Threads: Need Help
Irrigation / Sprinkler Forum Need help to fix broken copper tubing Nov 7, 2015
Irrigation / Sprinkler Forum HELP NEEDED FOR WINTERIZING MY SPRINKLER SYSTEM! Oct 21, 2015
Irrigation / Sprinkler Forum Need Help with Hydraulically Controlled Irrigation System Oct 13, 2015
Irrigation / Sprinkler Forum Need HELP on how to splice cut underground sprinkler wires Mar 11, 2014
Irrigation / Sprinkler Forum Huge water bill - need help Nov 19, 2013
