saraujo
I am tiling my bathroom floor. It's currently a little off level and may still be when I'm done. I'm planning to re-use my existing toilet for now to limit the costs. I want to mount it in such a way that it will be solid and level even if the floor is not and I want it to look good. The trick is I also want to be able to replace the toilet later without leaving traces of the mounting material stuck to the tiles.
I was considering using grout or plaster on the toilet base with plumber's putty as a distant third choice. I think grout would look best and be most durable but may be hard to remove from the tile later when I change toilets. From what I read plaster of paris works well but is a little old fashioned. I think it may be easier to remove from the tile later though. I'm pretty sure plumber's putty would be easiest to remove but is my last choice. It just doesn't look that good and I don't think it will stabilize the toilet base as much as grout or plaster.
One thought I had was to put the grout or plaster in place on the floor over plastic wrap, then put the toilet in place and let the material set, then lift and remove the plastic leaving the material on the toilet, then add the wax ring and johnny bolts to mount the toilet permanently.
Will this work with the plastic wrap? Would grout or plaster work better in this scenario? If this won't work and I have to put the material directly on the tile, would I be able to remove grout or plaster from the tile later without traces?
Any other thoughts?
Thanks,
Scott
Any other thoughts?
Thanks,
Scott
