Minimum pipe size for a toilet vent?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lahabra, Dec 22, 2007.
  1. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    According to my hand book the minimum pipe size required to vent a toilet is:
    1.5â€
    Or
    2†as a wet vent for a sink.
    Am I understanding this correct?
  2. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    What code are you using? UPC requires 2" for a toilet vent.
  4. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    Wet vent
    Ok so I need at least a 2†vent for my toilet.
    Can I also drain my sink into the same 2†pipe?
  5. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    I still don't know what code you're using, or how you're going about it.
  6. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    It depends on your location
    It really depends on your local in the USA
    I get away with murder in INDIANA with our code....
    1 1/2 pvc is big enough for the whole house to be
    vented onhere....
    other parts of the country expect a full
    3 inch stack out hte roof..
  7. Terry
    Aug 17, 2004
    With newer toilets that flush faster, you would want at least 2" on the vent.
    In some places you can wet vent a bathroom lav over a toilet, if that line is 2" or larger.
    A kitchen sink could not be wet vented.
    [​IMG]
  8. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    The book I am reading is a general construction book it covers everything from grading to roofing. The book dose not tell me specifically what size vent I will need for a toilet; however, it dose have tables soused from: "UBC Illustrated training manual (Walnut, calif: International association of plumbing and mechanical Officials 1985)."
    In one table I read that a private toilet counts for 4 fixture units. The next table shows 1.5" pipe being capable of venting 8 fixture units. Based on these two tables it appeared that 1.5" pipe could actually vent 2 toilets.
    In the houses I have worked on I always see 2" vent pipes for toilets, add to that your reaction and the fact that I don’t want to get into a challenge with my inspector, I am definitely not going to install a 1.5†vent on my toilet.
  9. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    acording to UPC 2006
    Thank you for the diagram Terry!
    So It is ok to use a 2" pipe as a wet vent for a toilet and a bathroom lav. Would this setup be in compliance with: "UPC 2006"?
    It has been my experience that most cities in the LA basin don't make up plumbing codes; instead they simply adopt "UPC". But I will need to confirm it in my particular city.
  10. construct30
    construct30 New Member
    Jun 16, 2007
    NorthWest PA
    I have the third edition of the code check plumbing for 2006, the little flip job books, it says the IRC does not require a vent on a water closet for residential. What's up with that?
Similar Threads: Minimum pipe
Plumbing Forum, Professional & DIY Advice Minimum 'collar' for sweating pipe Dec 21, 2013
Plumbing Forum, Professional & DIY Advice What is the minimum slope required for horizontal toilet drain pipe? Apr 21, 2012
Plumbing Forum, Professional & DIY Advice Minimum height for laundry standpipe? Dec 22, 2010
Plumbing Forum, Professional & DIY Advice Minimum toilet vent size? Dec 11, 2016
Plumbing Forum, Professional & DIY Advice Minimum drop for toilet in basement Jul 8, 2016
