Main water line repair advice?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Microburst, Oct 17, 2008.
  1. Microburst
    Microburst New Member
    Jan 10, 2008
    I have a slow leak where the main water line enters my basement wall through a rubber boot. The leak is coming from around or behind where the boot is clamped to the water pipe. The main water line is blue in color and looks to be about ¾” or 1” in size. I am guessing the best approach to fix this would be to dig around the pipe on the outside of the house, cut and remove a section of pipe that enters the house, then replace this section of pipe. My question is, what kind of pipe and fittings should I use to do this and where can I get the materials? The house was built in 2003 and is located in the Atlanta area. Thanks!
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    As a homeowner without having the specialized PEX tools your best option is probably cutting out the bad section and putting in a new replacement piece using Sharkbite Couplings. Big Orange Box has them.
  4. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    But does the big orange have the PEX¿
    Might want to leave this to a plumber but I'm sure he'd appreciate you digging to the problem though!
  5. hj
    pipe
    Blue pipe is polybutylene, and if it breaks in one spot it will probably also crack elsewhere. PB tubing is typically replaced rather than repaired.
  6. Terry
    Aug 17, 2004
    When I've seen the blue pipe, it needed complete replacement between the incoming shutoff and the meter.
  7. Redwood
    Dec 15, 2007
    Service Plumber
    Polybutylene installed in 2003?:eek:
  8. Microburst
    Jan 10, 2008
    How can I tell if it is PEX or Polybutylene? Will it be marked as such?
    Also, can I replace the section going through the wall with CPVC coupled to the "blue pipe" on the outside, or is this not recommended?
  9. Terry
    Aug 17, 2004
    I missed the 2003 part.
    I doubt that it would be polybutene
    It could be PEX or Poly.
    The pipe may be marked on the side as to brand and type.
Similar Threads: Main water
Plumbing Forum, Professional & DIY Advice Main Water Feed - 20psi Pressure Drop When one Fixture is Open Dec 23, 2016
Plumbing Forum, Professional & DIY Advice Water Main inside has a slow leak Dec 14, 2016
Plumbing Forum, Professional & DIY Advice Main Water Line Basement Entrance - Does this look OK? Nov 25, 2016
Plumbing Forum, Professional & DIY Advice Cold water supply line connected to cast iron main stack? Oct 27, 2016
Plumbing Forum, Professional & DIY Advice How to fix main water line leak issue-repipeing or rerouting pipes Oct 7, 2016
