David Hansen
Hi,
I recently moved into a new build home. The water pressure felt low to me and the plumbers came out and measured the pressure at 43psi at hose bib. They said this area gets low pressure. I talked to my neigbors and they said they had no issues with water pressure. I measured the pressure at my neighbors on either side of my house at they both are at 70 psi. I called my utility provider and they came out and measured on both sides of the meter and got a solid 70 psi. The plumber came back out and replaced the PRV and we still were at 43 psi. The builer is saying it is within spec, but my argument is their has to be a reason it is dropping over 25 psi between the PRV and the hose bib that is only 25' away. Within spec or mot their is a cause and it could be a bigger problem later on.
Any speculation on the cause of this drop. I am wondering if their is debris in the line, or the pipe got pinched when they put the sidewalk in or something. I am open to any thoughts as I challenge the builder to investigate further.
Thanks
'Dave
Thanks
'Dave
