loose tub spout
Discussion in 'Shower & Bathtub Forum & Blog' started by suzyfitz, Sep 25, 2004.
  1. suzyfitz
    suzyfitz New Member
    Sep 25, 2004
    I'm new here. I'm reinstalling a Kohler tub spout that slips onto the copper pipe and has a hex screw to tighten. When I removed it I scored the pipe, making a pretty deep groove by twisting the faucet trying to get it off. Also, when it came off the white washer and black o-ring came off. Have I broken it? Water leaks at the wall. Any suggestions on how to make it water tight?
  2. Terry
    Aug 17, 2004
    If you don't have the rubber seal, you may want to get a new "slip spout"
    It may seal with the new o-ring, if not maybe some silicone will help with the seal. :)
  4. hj
    If you scored the tubing in the area where the "O" ring seals then you probably have ruined it and will need a screw on spout with a threaded adapter soldered to the tubing.
  5. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    File and Sand
    You can file out scratches if you haven't indented the pipe. You should be able to reassemble the o ring and white insert.
Similar Threads: loose spout
Shower & Bathtub Forum & Blog Loose shower arm and tub spout Apr 18, 2007
Shower & Bathtub Forum & Blog Loose new diverter spout Jul 11, 2006
Shower & Bathtub Forum & Blog Loose Faceplate Behind Tub Spout Apr 14, 2006
Shower & Bathtub Forum & Blog Shower valve screws keep coming loose! May 1, 2013
Shower & Bathtub Forum & Blog Help quick before I loose my tenant!!! Need a hot water solution fast!! Jan 17, 2010
