Leaking sprinkler heads
Discussion in 'Irrigation / Sprinkler Forum' started by L84toff, Apr 29, 2010.
  1. L84toff
    L84toff New Member
    Apr 29, 2010
    Brantford
    Hey folks,
    When I went to start our sprinkler system this spring, I discovered that both our sprinkler heads on the same zone are leaking. I find it very strange that both would have a leaking problem all of a sudden at the same time. We had the system blown out last fall.
    We have been doing some landscaping and although we've been careful not to step on either of them, it's possible someone did.
    We've been in the house about a year and a half but had no problems with the opening or running of it last year.
    The leak itself is at the top, appears to be coming from where the water normally comes out from when it's running. The head does not appear to be all the way down as I can press it down and the leak stops, at least for a moment or two. I've unscrewed the top part and hosed it all off, thinking there may be some debris stuck in it. But after replacing it, the leak continues.
    I was going to replace the heads with new ones, but like I said, it seems strange that both heads in the same zone have gone at the same time.
    Any suggestions would be greatly appreciated.
  2. BRD
    BRD New Member
    Jun 22, 2009
    irrigation contractor
    northeast
    The valve that supplies water to those two heads is probably stuck open. It may be something lodged between the diaphragm and seat, or maybe a worn or pitted diaphragm seat. A tiny leak at the valve diaphragm will cause water to dribble from the top of a head, usually most notable at the lowest head on the line. Easy to fix if your handy. Remove top portion of the valve and check for obstructions, and or a pitted diaphragm seat. Be carefull during disassemble as there is a spring in there that should not be lost. Also do not forget to shut the water off first.
  4. L84toff
    L84toff New Member
    Apr 29, 2010
    Brantford
    Dumb question edited.
    That's exactly what it was. Problem appears to be fixed.
    Thanks very much.
Similar Threads: Leaking sprinkler
Irrigation / Sprinkler Forum Leaking sprinklers when system is off Feb 19, 2014
Irrigation / Sprinkler Forum Leaking Sprinkler Valve Dec 5, 2009
Irrigation / Sprinkler Forum Sprinkler Leaking...Now What? May 4, 2008
Irrigation / Sprinkler Forum Leaking Watts Backflow Preventer Oct 12, 2015
Irrigation / Sprinkler Forum Leaking Febco backflow valve, only when 1 specific zone starts? May 13, 2012
