Leak coming from bathtub
Discussion in 'Shower & Bathtub Forum & Blog' started by MRay419, Jan 12, 2007.
  1. MRay419
    MRay419 New Member
    Jan 12, 2007
    I have just moved into a brand new townhouse. There is a guest bath that adjoins my son's bedroom. An area about the size of a manhole cover has appeared in my son's room that is soaking wet. We do not take showers in this bathroom but I occasionally take a bath. It seems to have appeared after my taking a bath for a couple of nights in a row. (This is the second time this has happened within a month but we got the area completely dried out after the first time and now it has happened again.) The first time, the builder found that some pipe or something behind the drain had been damaged during installation and they repaired it. That's when we got it all dried out and thought the problem was solved. I have not taken a bath in it since until just a few days ago and now it has reappeared. There seems to be no apparent cause for this problem because the water damage is kind of out in the middle of the floor with no obvious path of water leading to it if that makes sense. To me, it seems obvious that whatever is happening is happening after I take a bath but the builder insists that he has filled the tub up several times and let it drain and can't find a thing. He keeps trying to put it off on my son saying he's not pulling the shower curtain closed enough when he takes a shower and the water is running out of the tub, onto the floor, back under the tub and into his room. Impossible since we don't use the shower but he will not listen to me. I need advise cause I am not a plumber and don't understand everything the plumber is claiming but I'm also no dummy and know that he cannot be right. But I don't know how to discuss it with him without knowing more. Please help!
  2. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    tape the shower head shut for a month or longer
    looks like you are in for a long fight.
    if you tape the shower head shut, and you tell the builder and his plumber that you are about to do this, it means you are ensuring beyond all doubt that no-one is showering from that shower, even when you are not home. They will understand that they are dealing with someone who is methodical, able to plan a process of elimination, and able to communicate and explain it in advance. This is the best kind of correspondent to be if "they" are honest, and the worst kind of adversary if "they" are dishonest. They may be operating with all the good faith in the world but just not be able to see the leak. It happens.
    Either way you win. Eliminate that possibility.
    diagnosing plumbing problems means getting down on your knees or belly a lot and getting dirty often. You now have to do it too since they are not coming back until the problem presents more information that will enable an accurate diagnosis. Enjoy the stretching, take it easy, like yoga.
    the first time around it is normal that you wouldn't learn all about the "thingie" that had to be repaired... now you have to get into this subject and study what there is there, what connects to what, what was apparently diagnosed, what was changed, what might be leaking, and more.
    put a few plastic bags over the shower head and tape each bag shut. Layers of plastic; look very convincing.
    post more here about the distances involved.
    david
  4. MRay419
    MRay419 New Member
    Jan 12, 2007
    Great idea and I see your point. And I can also see that you're right and I will need to learn a little more about the 'mechanics' of how a tub works. I will begin to arm myself with more knowledge! :)
    As for distance...hmmm...I'm gonna say that it's maybe 3 feet away if you went directly through the wall.
    Thank you so much for all of this....you're a great help!
  5. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Try to find the plumbing access panel. If there is one, it will be located directly behind the business end of the tub. Remove the panel. Fill up the tub and then drain it while looking around at the drain pipes (including the overflow) with a flashlight to find the source of the leak.
Similar Threads: Leak coming
Shower & Bathtub Forum & Blog Water coming back up air valves in jetted bathtub?? Causing leak??/ Jan 29, 2011
Shower & Bathtub Forum & Blog Where is this leaking coming from =( Nov 11, 2004
Shower & Bathtub Forum & Blog Shower Leak to basement... Feb 10, 2017
Shower & Bathtub Forum & Blog New tub & shower enclosure - leaking on floor - shower curtain Jan 22, 2017
Shower & Bathtub Forum & Blog Is this Grohe leaky tub spout diverter repairable?? Jan 2, 2017
