Jedd De Lucia
Hi, I am installing three valves in a new shower. This is a DIY project and I'm new to plumbing. I'm using a stack of Kohler valves. In the middle is a temperature/volume valve. Hot and cold inlets on the side and 2 outlets on the top and bottom. Below I'm installing a volume valve for body sprays. above there is a diverter feeding a rain shower, hand shower and standard shower head.
I have soldered the connections but the valves all have female threads. I installed copper threaded adapters with a short stub of copper pipe so that I could solder before connecting it and then solder the next joints further away from the valve, as the directions say.
I used pipe thread goop, or whatever it's called, for the threaded connections, not tape.
None of my soldered connections leaked (hooray!) but I do have 2 threaded connections which are leaking. What should I do? is there a better method of connecting copper pipe to thread? should I use a brass adapter instead?
Also, at this point what should I do? how can I get the threaded connection disconnected and fixed without taking everything apart? See pics attached. thanks for the help!!!
Final question, since none of my solders joints leaked, am I in the clear for leaks on those or will a bad solder work at first but fail after time?
