Irrigation Pump help!
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by busterheyman, Jul 2, 2008.
  1. busterheyman
    busterheyman New Member
    Jun 10, 2008
    Human Resources
    Weston, WI
    I have a 2" sand point down about 35". Water level is at 26" I am using a Sta-rite 1 1/2 HP Horizontal multi-stage jet/centrifugal pump (Model HMSF). This is a single pipe system with 30' of 1 1/4" pipe into the 2" Casing.
    I installed the system about 4 years ago and I was getting a flow of about 12 gpm. Water level was at 26'. This year when I started up the system I am only getting about 5-6 gpm.
    So far this is what I have tried:
    1. I have pulled up the interior pipe and replaced the entire jet assembly/leathers. (Still only 5-6 gpm)
    2. I rebuilt the interior of the pump. Impellers/wear rings/gaskets were all replaced. (Still only 5-6 gpm)
    I am not sure as to what to do next?
    My sprinkler systems was setup using a 12 gpm flow and now it doing a very poor job.
    Help!
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    I assume you mean the Leathers on the Single Pipe Jet. Right?
    That's a lot of Pump for that kind of water level and well size. That is one of Sta-Rite's most expensive Pumps and the two Impeller design is for deeper water levels. Like 60 foot plus. The extra Impeller in your situation is hindering water flow instead of helping it. Nonetheless, you have already discovered that you rebuilt the Jet and Pump for nothing. Now is time to look at the Well. That is your problem. Either the screen is plugging up, or the water level has dropped.
    bob...
  4. busterheyman
    Jun 10, 2008
    Human Resources
    Weston, WI
    So any advice on how to easily try cleaning the screen?
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Nobody said it would be easy.
    Is this Sand Point out the end of the two inch pipe or attached to the end of it?
    bob...
  6. busterheyman
    Jun 10, 2008
    Human Resources
    Weston, WI
    The sand point is an extension of the two inch pipe.
    Would turning the two inch and running a garden hose down it do the trick?
  7. speedbump
    Jul 15, 2005
    Riverview, Fl.
    So your saying it's a two inch point screwed to the bottom of the two inch pipe?
    No running a garden hose down the pipe won't help at all.
    bob...
Similar Threads: Irrigation Pump
Pumps and Tanks Well Forum & Blog. Water is life. Irrigation pump not working May 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Two pumps one irrigation system Dec 31, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Pump for a small scale drip irrigation system? Aug 24, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Question About Pump Pressure To Irrigation System Jul 26, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Irrigation pump loses prime overnight Aug 26, 2013
