Sans1964
Ok I have a 380 foot deep well a new 3 wire 1 hp gould at around 340 feet . Wster at Round 150 from well top. new pressure switch 40/60, new breaker in the panel, new fuses in disconnect. Pressure tank at 38 psi. Problem is randomly no water. Could be days before it happens . Throw the switch a bit later I can turn it on and get pressure. This can happen even after 24 hours of no water use. The system holds pressure and water is clean. I think the pump is going into overload, I measure around 7 amps at running. I should note that the pump was installed 2 weeks ago. Previous pump exhibits same symptoms.
TIA
Scott
TIA
Scott
