Insulating R5 'Penitentairy tile' walls
Discussion in 'Remodel Forum & Blog' started by therealmatt, Nov 20, 2012.
  1. therealmatt
    therealmatt New Member
    Nov 20, 2012
    new mexico
    I live in a 1 floor + full basement 1929 home, pitched roof with old Spanish tiles on top. The walls are plaster/pen-tile/stucco. 'Pen tile' is a hollow (3 chambers) brick block about the size of a toaster. I did some math, calculated that these walls are about R5. The steam radiators and solar gain keep the south side of the house warm, but the north side is pretty cold in the Albuquerque winter. There are 3 layers of attic insulation and I've fixed most of the air leaks. I have exterior storm windows. I had a door blower test that helped me find all the leaks. I plan to live here another 30 years or so. I'm considering increasing the comfort and lowering heating/cooling costs by adding insulation to the walls.
    I've gotten all kinds of advice:
    - build a new foundation outside the existing foundation and build a new wall on top
    - screw ridged foam insulation to the outside of the walls, stucco onto the new foam.
    I figure that putting insulation outside of the R5 brick will insure that moisture diffusing from the inside will hit the dew point in the middle of the foam insulation.
    I'm not sure about screwing foam to existing stucco and having it hold the new stucco in place for another 40 years.
    Any comments or questions welcome!
    Matt
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    Got a zip code? (To more closely specify the local climate, which varies a lot within NM.)
    I assume this is a 2-chamber variant of your stuff?
    [​IMG]
    With an all-masonry wall dew-point calculations hardly matter- masonry isn't susceptible to moisture and as long s you don't have highly vapor-retardent interior finishes like vinyl/foil wallpapers it'll dry toward the interior under any circumstances.
    For a foam-over job with rigid foam the thickness you can attain depends a lot on what you intend to do for exterior siding, since the fasteners for the foam will be carrying the weight. The mechanical strength of stucco-clad pen-tile probably quite a bit less than that of concrete, so hanging stucco 5-6" out probably isn't in the cards. But 3"(R12) maybe 4" (R16) of EPS would almost surely work. The fasteners would have to penetrate both the old stucco and the tile, but if all they're holding is metal lath fairly snug to the EPS you could get there with the masonry screws 16" on center. It all depends on the strength and integrity of the type of pen-tile used. If yours have an almost glassy hard-fired surface it's much stronger than the dull earthenware/terra-cotta look. If it's a softer type you may need to drill all the way through and use a through-bold with a flange/plate on the interior side to distribute the load over the interior face of the tile block.
    Assuming your R5 estimate is about right, 3" of EPS would yield a whole-wall R of about R17, which would beat 2x6 timber framed/wood siding construction (~R13-R14 after the thermal bridging of the framing is factored in.)
    An EIFS approach would be much lower weight and you could go fatter, but an EIFS finish wouldn't match the original stucco very well. But as a low-mechanical load system it might be the cheapest way to go with the least number of mechanical strength issues.
    With the increased wall thickness you'd have re-work the window & door flashing on that side, but with an all masonry & foam approach the wall would be fairly tolerant of flashing faults, even if the window frames had issues.
    If the additional wall thickness needs to be more structural & self-supporting or you want to go higher-R there are SCIP (structural concrete insulated panel) systems out there to build up wire reinforced concrete skins as the scratch coat for the stucco, but that would require building out the footing of the foundation to support it, eg: http://scconcretehomes.com/ Clearly SCIP is more expensive than a 2-4" foam-over with EPS and metal lath stucco tied to the original wall with masonry screws, but it's a very solid & durable way to build an insulated stucco clad wall.
Similar Threads: Insulating 'Penitentairy
Remodel Forum & Blog Insulating cantilever and rim joists Dec 29, 2014
Remodel Forum & Blog Walkout basement finishing - insulating walls above and below grade Sep 9, 2014
Remodel Forum & Blog Finishing Basement - Insulating Walls and Floors May 16, 2013
Remodel Forum & Blog Insulating Brick home in OK? Aug 3, 2012
Remodel Forum & Blog Finishing and Insulating garage walls Jul 31, 2012
