Installing a Tankless Water Heater, with Video
Discussion in 'Tankless Water Heater Forum' started by Terry, Feb 24, 2011.
  1. Terry
    Aug 17, 2004
    Here is a nice video of Tankless Guy's installation of a Navien Tankless Water Heater.
    [video=youtube;U7kzE0IzbgA]http://www.youtube.com/watch?v=U7kzE0IzbgA[/video]
  2. mcconnellplumbing
    mcconnellplumbing Scotsman
    Dec 31, 2010
    plumbing contractor, 25 years, high end residentia
    Wellston, OK
    The A in 240 A designates a circulating system with buffer tank. I didn't see the circulation loop return line installed or tied in at the bottom of the unit, the condensate drain line installed, or the temp and pres. relief valve drain installed. In the attic I would question the rigid plastic water filter and cannister unless in a warm climate. Code requirements here do not allow the condensate drain to tie into the T & P drain line. They also require a pan and pan drain under the tankless water heater.
  4. mcconnellplumbing
    Dec 31, 2010
    Wellston, OK
    One other note, by using the 3/4" Vanpex fittings, you are effectively reducing the inside diameter of the water line to 1/2" at each fitting. The unit has 3/4" inlets and the reduced inside diameter fittings will reduce the potential volume of water flow through the unit. We use 3/4" hard copper, type L or use 3/4" Wirsbo/Aquapex fittings and tubing. Good to see a real 3/4" ID gas supply line. A lot of plumbers use a 5/8" ID flex gas supply and it will limit the gas flow and throw the unit into an error code when running high.
  5. markstoppard
    markstoppard New Member
    Sep 18, 2011
    Indianapolis, Indiana USA
    Very nice...thanks for posting! This should help me get started :)
  6. BizzyBeePlumbing
    BizzyBeePlumbing New Member
    Aug 21, 2011
    Raleigh,Nc
    agree with mcconnel
  7. trytankless
    trytankless New Member
    May 14, 2013
    Sales / Administration
    Irvine, CA
    This video is very helpful. I actually sent it to a couple friends of mine who are on the fence about switching to tankless.
Similar Threads: Installing Tankless
Tankless Water Heater Forum Installing 2 Tankless - Did my plumber do it right? Sep 5, 2014
Tankless Water Heater Forum Installing gas heaters & tankless water heater, Jacuzzi J-sp-180w Apr 5, 2013
Tankless Water Heater Forum Saving water here in California buy installing mini water heaters at point of use. Jun 3, 2016
Tankless Water Heater Forum Installing Stiebel Tempra 24 Electric...Wire! Mar 14, 2014
Tankless Water Heater Forum New to tankless water heater and can't figure it out! Mar 16, 2017
