install schluter flange to trap
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jerome7, Jun 8, 2013.
  1. jerome7
    jerome7 Member
    Nov 14, 2010
    95020
    Hi all
    I want to install a Schulter flange for my shower and the instructions says I need to press it down on the mud bed.
    However my ABS drain pipe is flexible and goes down upon applying pressure. How do I ensure the flange is well connected to the pipe?
    Note my subfloor is still not in place, thus I still have access to the drain pipe.
    Thanks
  2. Terry
    Aug 17, 2004
    You can use a cat claw to reach down and "grab" the ABS pipe and prevent it from pushing down.
  4. jadnashua
    If you can figure out what height the trap should be at to allow you to bed the drain properly, you could add some blocking to prevent it from moving, or strap it.
  5. jerome7
    jerome7 Member
    Nov 14, 2010
    95020
    After I replaced the trap, I was able to put some blocks under it.
    Just curious, if I were to use a cat claw, do I grab by putting it inside the pipe?
    Outside will be hard given schluter has such a big flange.
Similar Threads: install schluter
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Corian tub/shower surround installed over Redgard Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Towel Rail Radiator Installed Sideways Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Delta Tub Spout Installation Questions Jan 10, 2017
Plumbing Forum, Professional & DIY Advice Reverse Osmosis Drain Line Installation Jan 8, 2017
