winky10
I am remodeling my home and need to tie a 3" DWV into my existing 4" main. The problem is that there is no place to tie into that I can see. The easiest thing for me to do, in order to incorporate all of the plumbing, is to extend the Main another 20 ft so that it can pass under central air ducting, allowing me to drop 3" lines into it at various places. Can anybody suggest a way to do that? The photos attached should give you an idea of what I''m looking at. The existing 3" lines would be replaced/moved. I know that using the cleanout to extend the pipe is prohibited, so I'm not sure what to do, given that the current fittings take up ALL the room. (Please ignore the electrical cable and sloppy supply PEX. The crawl space has since been insulated and encapsulated and the wires and PEX properly secured).
