ryan_siefring23
Engineer
Ok, so the two toilets up stairs work just fine. All drains in house are not an issue. However, the downstairs toilet when flushed does not flow out the water in the bowl.
The toilet downstairs is only about 4 feet from the main sewer connection to the foundation. I've snaked 15 feet of the line from the toilet to the sewer and found nothing. When I took the toilet off the flange there wasn't water in the drain until about 8 to 10 feet down.
So now I've got to explain why all the other drains work fine if this one is an issue. I was told that if this is the issue wouldn't the water level in the downstairs toilet raise up when we flushed up stairs toilets or ran the washer, ect.
Could it possibly be that the vent line is clogged for some reason? Please help me understand why you have told me the sewer line is blocked if everything else works.
Thanks,
Ryan
Thanks,
Ryan
