Help installing toilet flange
Discussion in 'Toilet Forum discussions' started by lordmoosh, Mar 31, 2013.
  1. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    One would hope that the stack is supported, but I would never take that for granted. A couple of riser clamps blocked in from above is all that it takes.
    If I am understanding your question about the flange, the pipe should bottom out (or be very close to it) in the hub when the cement is applied. If that is the outside fit flange, the riser should come up to about 1/8" from flush with the finished floor.
  2. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Would you put a cast iron wye or a pvc wye in between the cast iron thats there right now?
  3. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I would stay with the cast iron. If anything shifts a bit during the next 20 years, I would not want the load of the stack placed on a piece of PVC.
  4. Terry
    Aug 17, 2004
    It looks like no-hub cast iron in there now. If you replace santee on the stack, stay with no-hub.
  5. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Thanks
  6. Terry
    Aug 17, 2004
    The lav, should have had a vent going through the roof.
    Otherwise it would be an illegal S trap.
    Bringing the lav waste back to a side outlet santee would still not vent it.
    Reusing the no-hub clamps should be fine.
    Would I remove the santee?
    Nope!
    I still think there is a vent on the lav above the existing p-trap connection until proven wrong.
    One way to see, is to run water down the sink/lav and see if the trap siphons.
  7. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    We can only believe what you have told us, which is that the sink is not vented.
    I would not believe Terry's simple test of running some water into the lavatory because of the potentially low flow of the sink's faucet. You would need to drain a full sink or dump a bucket of water into it, and then check to see if the the trap has siphoned.
    If there is not a vent, it might be one of those times that an AAV will have to make do.
  8. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Gotcha. One question... you said you would not remove the santee. Are you saying this because your earlier suggestion to add the wye after the elbow is ok? Thanks.
  9. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The wye downstream of the bend would be correct IF the lav is properly vented. Either way requires the lav to be vented.
  10. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Ok thank you.
  11. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Thanks I will try this test. Do I basically open the trap and see if its not full of water after draining the full sink?
  12. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Yes. If the sink drain is without a stopper, you should me able to shine a light down the trap and see if it is full.
  13. jadnashua
    When the waste exits the P-trap of the sink, and before it starts to go down, there must be a pipe coming off that arm within 42" for the size pipe you are using that goes up to act as the vent. Since it looks like the sink's drain just goes straight down in the wall, there MUST be a vent line going straight up from where it transitions from horizontal to vertical off the trap arm behind the P-trap, or it is an S-trap. Depending on the flow, you may or may not be able to siphon the trap in the sink, so the test is not definitive.
  14. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Thank you.
  15. jadnashua
    Some places allow an AAV, some don't. Having one is better than an S-trap. They can and do fail eventually, so they must be placed where they can be accessed. You want is as high in the cabinet as you can reasonably get it and still unscrew it to replace it.
  16. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    If I go with an AAV in the cabinet, does it make any difference whether I put a wye at the main stack or after the toilet elbow? Thanks.
  17. jadnashua
    You don't really want to keep it into the toilet fitting, but I don't think it really matters which other choice you make once you've got the sink vented.
  18. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Thanks
  19. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I'm still wondering why you don't just vent the sink and cut the sink drain wye into the toilet waste arm, downstream of the closet bend?
  20. lordmoosh
    lordmoosh Member
    Aug 25, 2007
    USA
    Thanks
Similar Threads: Help installing
Toilet Forum discussions Porcher Veneto: Need help installing Piston Jul 9, 2016
Toilet Forum discussions Need help installing 3x4 lead drain pipe on 3" steel pipe Mar 15, 2015
Toilet Forum discussions installing 6" backflow valve on drainage help. Oct 18, 2014
Toilet Forum discussions Installing a toilet Help Jun 8, 2013
Toilet Forum discussions Need help installing American Standard Boulevard Luxury Toilet Seat Mar 25, 2013
