Help! drain too close to wall for toilet to fit
Discussion in 'Toilet Forum discussions' started by chelsea, Mar 6, 2008.
  1. chelsea
    chelsea New Member
    Mar 6, 2008
    Hello, I'm new here. :) I am in the process of redoing the flooring in my bathroom, and decided to also replace the toilet. The toilet that has been there since I moved in was apparently too deep to fit correctly. Whoever installed the toilet realized too late that the drain was too close to the wall for the toilet to fit, so they cut a hole in the drywall behind the toilet (in the shape of the toilet tank), so that the toilet could be installed. The toilet tank sits about 1" into the wall. As you can imagine, this looks absolutely horrible.
    Is there anything I can do besides having the drain moved to correct this situation when installing a new toilet? I have removed/installed many toilets in the past, but I really don't know anything about plumbing other than how to do that. If I purchased a toilet with a "10" rough in", would that correct this situation and allow me to patch the drywall hole behind the toilet and have the new toilet fit correctly? I have measured the distance from the toilet bolt to where the drywall should be, and it measures 11".
    I would GREATLY appreciate any advice anyone could give me. :)
  2. Terry
    Aug 17, 2004
    If you have 11" from the center of the drain (bolt is usaully about there) you can use a newer 12",
    the Toto Drake would work, and maybe some others.
    Your other choice would be to get a 10"
  4. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    For a matter of 1/4", in some cases you can shim the back of the bowl so its slightly tip up in the back and steal a bit more at the tank installation so that it tilts forward a little bit.
    It would all depend on the type of WC you are using and you have to make sure that the bowl is well supported around the entire perimeter .
Similar Threads: Help drain
Toilet Forum discussions Help! Broken flange that was resting on crumbling mortar, bolt down drain!! Sep 15, 2016
Toilet Forum discussions Weird toilet sewer drain help??? Jul 26, 2016
Toilet Forum discussions New (to me) toilet drain? Need help wth this one! Jan 25, 2016
Toilet Forum discussions Need help installing 3x4 lead drain pipe on 3" steel pipe Mar 15, 2015
Toilet Forum discussions installing 6" backflow valve on drainage help. Oct 18, 2014
