Shattered2020
USA
Hello all,
I have a Hamilton Beach Glacier Series Water Softener. Here's the manual for it: http://ngsales.net/valves/tech_hb.pdf
I just performed a water test and everything came out ideal with water hardness at softest level and iron content at lowest testable result (same with copper, nitrate, etc...).
So what's the problem you may be asking. The problem is the water softener is regenerating every single day and costing a fortune on the water bill and driving water usage up in this drought affected area I live in to the point where it's going to become a problem with the utility company.
I checked the settings and the time of day is correct and the time of regeneration at 2:00 a.m. which is the default which is fine but I have no idea how to determine what the hardness, salt amount (and we use potassium not salt so...) and the capacity numbers should be.
There's about 190 lbs of potassium chloride in the stand alone dry tank.
Can anyone help me determine the correct settings to finish the level 1 programming?
