TexasHokie
I’ve done this or similar repairs at least 15 times (home owner for 30 years and own rental properties)
I believe this is a 15 year old American Standard. Just says Vitromex on the inside of the tank.
I’ve replaced the 2” flush valve 2x’s now with both HD & Lowe’s kits. The Loews kit is the Fluidmaster. I’ve even swapped the rubber gasket/seal on both.
I have cleaned both inside and out and tightened down as hard as I can. I even have a flat plumbers adjustable wrench that gives me plenty of torque.
I have the tank sitting on top of a sink with the bolts & fill valve installed. The Fluidmaster gives me about an inch of water until it reaches the flapper, so I know the leak isn’t the flapper.
I can try installing it, but it’s only going to put me back to my original problem...tank filling for 10 secs once an hour.
I’ve looked closely & I don’t see any cracks.
The only possible issue I can see is the outside tank bottom isn’t flat for the entire diameter of the plastic nut. It does slope slightly as it approaches the front. However, the seal/gasket feels tight, and there a tight visual seal.
Is it possible I’m over tightening?
I have searched for a genuine AS seal, but nothing resembles what I took out, and the flush valve is original—have checked other toilets & I’ve lived here since new.
Thanks for the input.
