flexible pipe at WH
Discussion in 'Water Heater Forum, Tanks' started by 68malibu383, Jun 4, 2012.
  1. 68malibu383
    68malibu383 New Member
    Dec 15, 2009
    Colorado
    I can't locate my list of approved piping materials that connect to the inlet/outlet on the water heater but I don't think this one (photo) makes the cut. Please advise.
  2. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    Why not? There must be hundreds of thousands of stainless steel flex connectors installed on water heaters already. Perfectly legal anywhere I know of, as
    long as they are NSF approved.
  4. jadnashua
    Some places require flexible connections, some places require rigid connections, some places allow either as long as they are rated for this use. Places subject to earthquakes generally require a flexible connection and straps to hold it to the wall.
  5. Terry
    Aug 17, 2004
    I like the stainless flex connectors. I also use copper.
    You don't use tape on the threads though. They come with rubber washers on the ends.
    Some people use tape in the most useless places. The sealing takes place at the end of the pipe where the rubber washer is, not on the threads.
  6. hj
    That is an "approved" material, although it could have been installed a lot more neatly than that. I do not use stainless, but rather use the copper flexible lines, but is is strictly a personal preference.
  7. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Yes you are right Terry,
    but the plumbers tape doe's make the nut easier to tighten onto the nipples,
  8. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    My experience is the exact opposite, tape in inappropriate places makes for more difficulty. Those nuts are not supposed to be made god-awful tight anyway, all you need to
    do is compress the rubber sealing washer, very similar to a garden hose connection. If you torque down on those nuts, you are probably damaging the seal.
  9. hj
    It does NOTHING to help or hinder the connection, unless you put so many wraps of tape, that the nut is too snug.
  10. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    WOW That sure is a hacked Job ! I use nothing but copper flexes. Plumb. and appropriate length ! Also our code requires 2 earth quake straps with 3/8" leg bolts.
    I install a lot of California earthquake shut off valves. 5.2or greater E.Q. and and it shuts off gas.
  11. hj
    YOU MUST use earthquake straps. It is a side benefit of living in CA. In most other areas it is not a requirement, or even a need.
  12. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The only things I would have done differently is to change the length of the intake pipe so that a short flexpipe could have been used and the sharp bends avoided. I will say that at least the bends look like they were carefully made so they are not kinked, but shorter flex would have been easier as well as neater looking. You also have to abide by local and state codes on straps, shut off valve, etc.. California is very strict on those things, other places not so.
Similar Threads: flexible pipe
Water Heater Forum, Tanks Water heater venting: flexible b-vent? Dec 1, 2016
Water Heater Forum, Tanks TPR Valve--can I use flexible copper tubing? Dec 1, 2013
Water Heater Forum, Tanks State water heater outer vent pipe Jun 12, 2016
Water Heater Forum, Tanks Water Dripping From Water Heater Pipe Feb 15, 2016
Water Heater Forum, Tanks Black inky coating in copper flex pipe on hot side? Apr 20, 2015
