Bryan Klinginsmith
I am installing the rough in plumbing for a farmhouse kitchen sink with one center drain that will have a garbage disposal. This is remodel, but the kitchen sink has moved, so drywall is off and everything will be new.
Questions I have are:
1. Is height 14 - 16 inches from floor OK for farmhouse sink with 10" deep bowl.
2. With one center drain with garbage disposal, should the drain line be offset from center line of sink. If so how much?
3. Should drain line be straight out from wall (perpendicular), or at a slight angle? I have always done straight on lavatories but have seen pictures on line where the line is at an angle toward the center of the sink.
4. The drain line will be 2" with 1.5" vent, but is the line out of the wall from sanitary tee 1.5" or 2"?
5. The sink is under a window so vent line runs horizontal slightly below the countertop height before turning vertical. Approximately 5 feet away. This is how it was originally when the house was built. Is this OK?
