Enough mortar banking?
cheetah chrome
Melbourne Beach, FL
Hi,
First off not a pro, read this forum extensively regarding the job at hand and it has gone perfect...so thanks to all. Ok, I set an acrylic jacuzzi tub yesterday in a mortar bed and then banked the perimeter w the exception of a small section so I could inspect the drain for leaks. Ran a couple of leak tests and none found. I am going to mix up another batch of mortar to finish up the small section but wanted to ask if what I have banked so far is enough. Bank is approximately 5"s up from the floor.
cheetah chrome
Melbourne Beach, FL
Looks like a tank.
I would think you have enough mortar under there.
Nice use of the plastic as a bond breaker....
Excellent. I got a bulk of my information on the job from your threads so thanks. The bottom of the tub is solid! The fluffy piles of mortar between each of the foam feet worked perfect. This, and moving/blind setting the new drain in a slab, were the steps of the remodel that I had the most fear of screwing up. Read a bunch on here and measured...measured...and measured again and it went perfect.
JohnfrWhipple
BATHROOM DESIGN & BUILD
North Vancouver, BC
.....Read a bunch on here and measured...measured...and measured again and it went perfect.
I like to say "That was Lucky" - in a kidding sarcastic manner. You can never plan too much or stress to little. You only get one chance to nail it perfect.
"When it's Perfect - It's Good Enough." JW
