Does this configuration work for a laundry sink and washer box
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by logan, Nov 14, 2010.
  1. logan
    logan New Member
    Nov 9, 2010
    Toronto, Canada
    Hi guys, I'm a bit of a newbie to this so forgive me if this has already been asked. I've researched what the proper venting for a laundry sink and washer box should look like (including Terry's picture) and I think that I have it right. I'm wondering if anyone would be able to take a look at my pictures and let me know if it's correct or what I would need to change.
    Forgot to mention the pipe at the top is the vent pipe (venting out to the roof) and I've placed the P trap for the washing machine 7 inches below the P trap for the laundry sink.
    Thanks in advance, I appreciate the help.
    Thanks
    Fernando
  2. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    How do you plan on securing those pex stub outs for the sink?
  4. logan
    logan New Member
    Nov 9, 2010
    Toronto, Canada
    To be honest, I hadn't though that far ahead. Since I am going to insulate the wall with spray foam and then Roxul, I thought that might be enough to keep them from flopping around. Additionally, I could put in some extra bracing in the bottom of the cabinet to secure them further.
  5. dlarrivee
    Jun 28, 2009
    Canada
    I would go out of my way to space the framing 1/2" or more from the block wall if I were spraying foam on the wall. Then you get a thermal break behind each stud.
    I would also be using a drop ear elbow for each of those stub outs.
    Insulation isn't meant to support your plumbing...
  6. logan
    logan New Member
    Nov 9, 2010
    Toronto, Canada
    Thanks for the suggestion. I've actually pulled the framing off all the walls a little over an 1 inch since the spray foam will be applied at a 2 inch thickness for the thermal break. I wanted to make sure that the spray foam guys could hit each inch of the wall behind the framing. Does the venting look ok?
  7. dlarrivee
    Jun 28, 2009
    Canada
    It looks okay to me but I spray foam for a living, I'm no plumber. :D
  8. Terry
    Aug 17, 2004
    The waste line should be 2".
    The p-trap in the wall should be a solvent weld p-trap, not a swivel.
    The vents can be 1.5", and the trap arm for the sink. The washer p-trap should be 2"
    For the others, PEX is normally run with very few fittings. PEX bends, and sometimes you can install with just the ends, and no fittings in between.
    Plumbers don't like shark bites as an every fitting replacement. If you're running copper and PEX, use those fittings, either the proper brand of fitting for the PEX, or for copper fittings that are soldered.
    A shark bite can be used in a pinch, but shouldn't be considered for general use.
  9. logan
    logan New Member
    Nov 9, 2010
    Toronto, Canada
    I post a pic of the spray when they're done then :)
  10. logan
    logan New Member
    Nov 9, 2010
    Toronto, Canada
    Thanks Terry. Unfortunately I'm tying into an existing 1 1/2" line so upgrading to a 2" line would mean cutting into the stack to run a new 2" line. If I leave an access opening for the washer P trap would that be good enough in case there was an issue in the future or should I just cut the pipe and do it over with a solvent weld P trap?
    I was worried about the pex kinking in the wall after it was covered so I opted for the elbows. I was trying to stay away from sweating a copper to pex adapter but it looks like that's what I should do.
    Otherwise is the venting ok for both fixtures?
  11. dlarrivee
    Jun 28, 2009
    Canada
    I would go through the trouble to tie 2" into the stack, the 2" washer standpipe/trap is a really good idea.
  12. Terry
    Aug 17, 2004
    An inspector wouldn't pass the 1.5"
    Change it at the stack.
    The venting is fine for Canada.
  13. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    Canadian minimum code allows 1.5" however I agree that 2" is better and if possible why not do it.
  14. christoff
    christoff Member
    Dec 14, 2007
    Toronto Canada
    are you allowed to use a san tee on it's back ?
  15. logan
    logan New Member
    Nov 9, 2010
    Toronto, Canada
    Thanks guys, I'll upgrade the waste line to 2"
  16. Terry
    Aug 17, 2004
    Not in Seattle. They would require a combo or wye fitting. But I don't know about Canada.
  17. hj
    A code is a "minimum" standard, which means it SHOULD work, but NOT always the best option. The drain should be 2" and it wll NEVER be easier or cheaper to do it than NOW. You actually did it backwards. The normal way would be to use a 2" drain and 1 1/2" vents, not 1 1/2" drain and 2" venting.
Similar Threads: Does configuration
Plumbing Forum, Professional & DIY Advice Does this sink drain configuration look right? Jun 7, 2012
Plumbing Forum, Professional & DIY Advice Small Radiant heat system - Does this look right Dec 23, 2016
Plumbing Forum, Professional & DIY Advice Does this plan for DWV look OK? Dec 14, 2016
Plumbing Forum, Professional & DIY Advice Main Water Line Basement Entrance - Does this look OK? Nov 25, 2016
Plumbing Forum, Professional & DIY Advice Does homeowner insurance usually cover water leaking fix(e.g. repipe or reroute)? Nov 14, 2016
