Does this Charge Seem Excessive
Discussion in 'Pumps and Tanks Well Forum & Blog' started by Cass, Sep 13, 2007.
  1. Cass
    Cass Plumber
    Nov 12, 2005
    To replace this well pump?
    Artesian Well 160' deep
    Pump set at 100'
    Charge for pump $800.00
    Labor to pull and replace pump $1000.00
    Total bill $1,800.00
    This is not my job.
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Sounds like a bargain
    And I would charge more just in case it is too low.
  4. got_nailed
    got_nailed DIY Senior Member
    Jan 11, 2006
    That is dirt cheap. What kind of pump did you get; $800 is cheap after markup.
  5. abikerboy
    abikerboy DIY Senior Member
    Apr 22, 2006
    VA
    A buddy whom Ive been helping out lately charges $300 flat for the derrick truck, plus $65/hour labor, and he only charges travel time if the customer is more than 30 miles from the shop. We just replaced a 1 hp 2 wire goulds a couple days ago, well was just under 350 foot deep, pump on sch 80 pvc w/threaded couplers. Nothing unusual, and no problems with the repair. Just a straight forward pull and swap. Ticket charge was $430 for truck and 2 hours labor plus $899 for the pump plus splice kits and tape. We reused the original pipe and cable, so no materials charges there. Guess wells and prices for labor/parts are pretty regional from what Ive read on here.
  6. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    $1800 isn't outrageous, and if the casing doesn't extend above grade, making it do so can be added to the basic pump replacement cost.
  7. Raucina
    Raucina New Member
    Jul 30, 2006
    toiletvalveguy
    If its on poly pipe: labor to pull- $50 - labor to replace pump on same pipe and wires- 150$ -Pump, 169$ rebuilt
    flo tech [lousy] or Graingers myers-400$
    Thats either $400 or $750 plus driving time. Seems like anything over that is profit and pump margin.
  8. dirtmover
    dirtmover New Member
    Feb 16, 2007
    Ontario
    The guy I just contacted has the following standard charges:-
    $1300 for 1/2hp
    $1400 for 3/4hp
    $1600 for 1hp
    These are Goulds pumps and he includes new poly pipe and wiring in the cost. Oh, maybe I don't really need this and he's just trying to pad up his margin. Anyway I also priced the same 3/4 Goulds pump at $900 so he's basically charging $500 for pipe, wire, supplies and time.
    ...and this is in Canada so I expect to get done over!
  9. rshackleford
    rshackleford New Member
    Oct 18, 2005
    Eastern Montana (The Bakken)
    looks good to me. sounds normal to cheap.
  10. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
  11. dirtmover
    Feb 16, 2007
    Ontario
    Good prices but of course,
    "No sales are authorized outside the United States"
  12. Rancher
    Rancher Guest
    WorldWide Power and Pump Services, Inc.
    Call them and ask anyway, UPS doesn't know the difference, if they say no, ask them about the "WorldWide" part of their name...
    Rancher
  13. Raucina
    Raucina New Member
    Jul 30, 2006
    toiletvalveguy
    I buy control boxes there - 1 and 1.5 big size box, cscr for 77$ really a bargain. Service has been good.
  14. dirtmover
    Feb 16, 2007
    Ontario
    Sure they do. UPS delights in cross border shipments because it gives them an opportunity to charge outrageous brokerage fees!
  15. Rancher
    Rancher Guest
    I guess my point was, that UPS has no problem shipping to Canada.
    Rancher
  16. dirtmover
    Feb 16, 2007
    Ontario
    I did a bit more searching and found www.aquascience.net sell the same Goulds 10GS07 pump I've been looking at for $523 which is about $50 less than www.wwpp.us and a whopping $358 less than I could get it for locally. Even though I hate giving UPS $50 for a bit of paperwork with the CAN$ at par I'll still save about $250 over buying locally!
Similar Threads: Does Charge
Pumps and Tanks Well Forum & Blog Pump doesn't seem to pull water Monday at 11:07 AM
Pumps and Tanks Well Forum & Blog Use water outside: water Stops - Inside water does not May 8, 2016
Pumps and Tanks Well Forum & Blog Does this make sense? Jan 8, 2016
Pumps and Tanks Well Forum & Blog Warm water smells, cold water does not Aug 21, 2015
Pumps and Tanks Well Forum & Blog Pump kicks on at 40psi but does not move higher May 28, 2015
