rompstar
we had some freezing temp here, so I shutdown my system, turns off power and drained the water and put a heater in the pump house...just incase, I didn't want to take any chances with broken pipes...
my Artesian Well is back to its natural pressure 12psi at pump house, but when I turn on the system, the Controller displays a "Pressure Sensor Fault", and was reading the manual for the controller and it said the
Pressure Sensor should read at Output between 0.5 ~ 4.5 volts DC / but I measured it 4.9 volts DC... and it said anything outside of this range is bad.
Do you guys really think the pressure sensor actually went bad reading at 4.9 volts ?
Also if so, I need to find a replacement for it, it is a:
MSP 300-100-P-3-N-4-01588 / 3 wire sensor / P/N 2001000
I tried to google, but I can't find it, maybe there is a new model number to replace it ?
Anyways, for now I am on natural pressure, which is better than nothing..
Thank You!
Thank You!
