JustinChase
I'm not sure of the right or best way to run the plumbing for the new laundry room. I marked up a photo of the framing in the room, with simple lines and some text.
Can I use an AAV for this setup safely (potential code issues aside)?
Do I need a p-trap in the drain line setup inside the walls for both the sink and the washing machine, or can I just have one for the washing machine, and install one under the sink (like I have it drawn)?
Do I need any special fittings to connect this all?
Do I need any extra lines to keep the drains and vents more separate?
Any other suggestions for plumbing this all correctly? Drywall is supposed to be installed next Wednesday
