Diagram of pipe... Will this work?
Jpb116
Massachusetts
Will this work or will the tub not drain properly? The main waste pipe is 3" and vent will be a 2 1/2". The vent would be ~6 feet from the tub drain. I'm concerned about the position of the vent...
I saw one plumbed like this, everytime the tub was drained, it backed up into the shower.
Jpb116
Massachusetts
or is this a better solution?
is this a better option?
Each p-trap should have it's own vent.
Wye off for the shower, vent using a combo, and tie back the vent at least 6" above the flood level of the fixtures.
whats up
no every time your bathtub drains it will suck the trap dry in the shower witch will make for a verry unpleasent smell.every fixture should be vented properly.
Jpb116
Massachusetts
Hmmmm. So would this be a problem?
On the other side of the room is the toilet and sink .. Would the configuration below work or is it a problem? By the way, Thanks Terry, this site is wonderful!
It works if you use a wye and 45 fitting (combo ) where the lav drops into the main line.
Jpb116
Massachusetts
Correction to original pic
So, The orginal question needs to be modified a bit. In the pic below please note that the vent that i want to tie into already exsists and serves a kitchen on the other side of the wall. So it seems that the stack up through the room would be considerd a wet vent, right? Does that change the rules at all?
Are the two rooms on the same floor; if so, it's not a wet vent? If not, then draining into the lower floor's vent makes it a wet vent and not the greatest solution. Depending on the size of the drain pipe, it may work okay.
Jpb116
Massachusetts
answer
It is a ranch, so I guess it's not a wet vent... I just want to be certain I should still do the laypout that Terry suggested above... I wasn't clear in my original drawing...
SRdenny
Plumbing Contractor
SF Peninsula
Whatever way you configure it, don't forget a clean out. And at 3' the wc doesn't need a separate vent. It can be wet vented by the lavy.
