Bassadict69
Over the years growing up in this house, I know of two different wells, neither of which are being used because of a community water system coming in and Dad switched over to it so there is no telling where the supply line comes in. Now, I am needing to determine where the main supply coming into the house runs.
The back corner of my house is a utility room and the hot water heater sits in the outside corner of that room. There is a wet spot in my yard at that corner so I have a leak somewhere. I have dug some hoping to find a supply line leaking at a point I can get to , but I have not even located a line. The hole I dug holds water and fills back up shortly after I empty it so I do know there is a leak there somewhere.
What is best way to find the supply line and where it comes into the house?
What options do I have if my leak is under the slab as it appears it is?
