Delta to Price Pfister Roman Tub replacement
cstdenis
Florida
I know this is probably a dumb question, but I am really confused. I have an old classic delta polished brass roman tub 2-handle faucet. I purchased a Price Pfister Marielle replacement which came with pipes, etc. I am having a hard time getting the old handles/pipes out of the tub and I'm really unsure about whether I can even do the replacement without tearing out tiles, etc. I thought it would just be a matter of changing out the insert to connect to the handle and change out the handles, but apparently I'm wrong. Do I need to get a plumber to do this?
Thank you.
Master Plumber Mark
www.weilhammerplumbing.com
stick with DELTA
Take that Price Fister back.....they are junk
you already have a Delta
all you go to do is go to a plumbing
supply house and simply buy the TRIM KIT for about 90 bucks..
in whatever delta faucet design you wish to install......
if the faucet is PB it is probably a mid 90s Delta
it is still interchangeable with MOST of the new stuff,,
and you should just have to change out the tub spout with
an allen wrench
and the new handles and escuption plates
should jsut screw off and you should be albe
to re-use the basic body
price fister is junk anyway....
wshful
Delta tub faucet
I'm trying to replace a Delta roman tub 10"faucet from 1986 and can't figure out how to remove it, there is no set screw behind the faucet. any ideas, thanks
Cass
While I am not familiar with that particular one, if there is no set screw to be found anywhere on the top side then it is held on from under the deck it is mounted on. If it is like many I have seen then you will have to gain access from some where and many I have seen are completely enclosed by ceramic tile which has to be broken to get there. Lets see if someone else has another idea.
roman tub
Spouts with set screws are a fairly recent innovation. The old ones were held in place by a lock nut under the deck and a drive pin into a hole in the dect to keep it from turning. For those you need to access the underside of the deck, but you would have to do that anyway to replace the faucet.
cstdenis
Florida
Will all delta faucets work?
OK, can I replace it with any Delta faucet/handles? I don't want the ugly acrylic ball handles anymore. I don't have a plumbing supply in my area.
Also, my escuption plate on the hot water handle is stuck. I tried WD40 and silcon spray. Any ideas?
Thank you.
Dunbar Plumbing
www.KoldBreeze.com
If you call Delta's 1-800 number and describe your situation, they will set you up with what you need in style and selection to retrofit to your situation.
That part you are having trouble removing; try turning it slightly in a tightening motion and then reverse motion. This sometimes opens the thread pattern and allows that small movement to allow the connection to free up.
jlohrenz
Yes,
Call Delta. Their CS is great. Stay away from Price Fister. We bought a faucet from them for our kitchen and it has been a PITA since then.
Good luck!
cstdenis
Florida
called delta - still confused
Well, I called Delta and they asked me "is the base of the current faucet square?" I answered the base of the current faucet (spout) is kind of rectangular. This freaked them out and they said they can't gaurantee that any new faucet will work with it. So I thought maybe we are not communicating and told them the hole in the tub was circluar and the valve stem was circular as well. I don't think I got my message across, because I got the answer "well you can try a newer faucet and see if it works." I don't feel like wasting $300+ just on an experiment. So I'm not sure what to do. I took some pictures of both the faucet and handle valves and stems. Can someone give me some advice please?
spout and valve:
handle v
alve:
Carol
The new Roman tub faucet by Delta does not match up with the old valve.
You're looking at a complete replacement of the faucet if you want to change the tub spout.
This is the new replacement here.
The old Delta Roman tub faucet removed. We had to enlarge the holes to 1-1/2" for the new stems and spout.
We removed six tiles on the side of the tub box to get access to the valve.
The Old Delta valve had been run in tubing smaller than 1/2". We wound up removing that and using PEX to the new valve, which by the way is now 1/2" copper.
I wish I had taken a picture of the rectangle we had cut out with a sawzall. The general borrowed our saw and did a nice clean job of it. He plans on reinserting it now.
The old tub spout was fastened from below the tub. There is no replacement without undoing it from the underside. The new trim does not work with the old rough. A new rough was needed.
Delta BT2710 was used here.
robert13084
waco, TX
You probably wont find just the trim since delta changed there faucets. Tear it out and put in a new one. Delta is junk! Pfister makes a better quality faucet!
At least they did. Not sure how they are going to be not that they are a China company, and have to comply with the anti-lead laws, which all companies will have to do somehow.
