Jefrf
I'm a pretty experienced remodeler helping my neighbor rough in a Delta Multichoice 22000 valve. The plan is to have a normal wall mounted showerhead and then a body sprayer which slides up and down on a vertical bar. The trim allows for three settings: shower, body sprayer, or both. The sprayer is fed via a hose from a small elbow nearby on the adjacent wall. I've put in plenty of "normal" valves before with shower head and maybe tub spout, but this one is obviously a more complicated because you have to feed each of the two from the correct outlet from the valve. Their directions are OK, so I think I can handle that part. I also know the importance of the rough-in depth and accounting for my tile thickness, etc. So I'm down to two important questions I could use some help from pros (y'all):
1) Since this will have more water coming out than just a single showerhead, should I bring 3/4" pipe for the hot and cold lines from his PEX manifod to the valve body, and then 1/2" out of the valve to each head? Or is feeding the value through 1/2" going to be enough.? Using PEX, so I figure the fittings will restrict a bit compared to if I sweat copper. But it's only two heads, not like the 5-6 that some really big fancy showers have.
2) The shower head will be above a nice big niche in the tiled wall and the valve is on an adjacent wall near the shower door. Am I allowed to have the drop-ear elbow for the showerhead come in horizontally or does it have to run vertically down before I elbow it over towards the valve? Every job I've done has had the head directly over the valve, so I never even thought about this before. I can't imagine why it would matter, but thought I'd ask rather than find out later I was wrong.
3) any other considerations for a different type of valve such as this? Happy to hear any advice.
Thanks. Terrylove forum is my go-to plumbing source. Appreciate all who give their opinions.
