CRANE - slow flusher
Discussion in 'Toilet Forum discussions' started by amat_plumb, Apr 29, 2010.
  1. amat_plumb
    amat_plumb New Member
    Apr 1, 2010
    CANADA
    CRANE - slow flusher - NEW brown color
    Have an older Crane toilet taht just doesnt work that great
    it flushes most of the time. not the best fulsh, kind of slow, not strong
    use plunger on it frequently. sometimes after plunged well, seems to work pretty good for a short while
    waht can cause this. Is there a blockage in trapway, or below toilet??? Are the jets/siphon jet not clean/blocked?? the tank is full when I flush, and fills ok.
    how can I troubleshoot this? should I just replace??
    I have a smililar model downstairs that doesnt have these issues
  2. Terry
    Aug 17, 2004
    More than likely you have something in the trapway of the bowl slowing down the siphon.
    Take a closet auger to it and see what you find.
    [​IMG]
    We use a closet auger with the large 1-3/8" end on it.
    Smaller cables can go right by the obstruction and not move it.
    [​IMG]
  4. amat_plumb
    Apr 1, 2010
    CANADA
    the auger i have doesnt seem to have an end on it at all. the wire just slightly is opened
    will try anyway
  5. hj
    HOW old is the toilet? Does it have a flapper in the bottom with a white styrofoam float? I have had toilets like that which have lost their floats inside the toilet which blocked the flow. Once, I removed FOUR of them from one toilet.
  6. amat_plumb
    Apr 1, 2010
    CANADA
    pretty old. i did replace flapper months ago. dont know what you mean about styrofoam floats. where do they get stuck?? in the flush valve/hole??
    there is nothing loose in the tank
  7. hj
    Assuming you have a Crane toilet with the molded china flapper seat, then the original, and many replacement flappers have a white styrofoam float on the bottom. Originally the tank to bowl gasket had plastic insert with "X" crossmembers to catch the float if it fell off. Quite often over the years that insert disappears and then the float can drop into the water passage that goes to the siphon jet preventing proper flushing. I remove them by heating a wire red hot, shoving it down through the flush valve opening, hopefully into the float, waiting minute or so for it to cool off and then pulling the wire out. If it penetrated it properly, it will be stuck to the wire and come out. Otherwise, you have to remove the tank so you can see the float and then remove it that way.
  8. amat_plumb
    Apr 1, 2010
    CANADA
    should these pieces of styrofoam be visible deep in the flush valve, or do I need to remove the tank to check
  9. amat_plumb
    Apr 1, 2010
    CANADA
    interesting detail
    forgot to mention. brown streaks seeping from top of bowl jets. also bottom of flapper is brown/discoloured(originally pink)
    no other discolouration in tank. could there be something in flush valve/ jet ring area????
Similar Threads: CRANE slow
Toilet Forum discussions I have a real problem. My toilet is a Crane Walsun and the tank is in the wall behind the toilet. Nov 20, 2016
Toilet Forum discussions Crane Walsan finally developed a leak ...Vintage May 31, 2016
Toilet Forum discussions Crane Walsan wall-hung toilet, Seeking a flush handle ... Nov 11, 2015
Toilet Forum discussions Crane walson wall mounted toilet Jun 3, 2015
Toilet Forum discussions Crane Walsan wall-mount toilets ...Considering replacing 3 Mar 29, 2015
