Connecting to outside sewer line
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hoopers2, Nov 6, 2012.
  1. hoopers2
    hoopers2 New Member
    Nov 6, 2012
    Texas
    Hello,
    I am adding a 2nd story powder room with a toilet and sink to my existing town-home.
    I am draining the two fixtures with a 3 inch line. The drain line runs down an exterior wall (on the inside of it), and then exits just above ground level. From that point, it is about a 7 foot run to my outside, 3 inch cleanout.
    Not sure how the cleanout line is tied into the horizontal exit line below.
    Can I "T" into this vertical cleanout line?
    Or must I dig down to the horizontal line that the "vertical cleanout line" connects into? If I have to T into the lower horizontal line, what is the best way to do this? One of those rubber connecting T's or something better?
    Thank you.
  2. hhplumbing
    hhplumbing New Member
    Oct 28, 2012
    Victoria, BC
    hello,
    yes you can tie into the verticle line, but you will have to use 45 degree fittings insted of 90 degrees elbows. and try and get it in the ground as soon as you exit the building
    hope this helps
  4. Terry
    Aug 17, 2004
    A horizontal waste line can enter a vertical with a Santee fitting.
    If you were dropping down to the horizontal line, that would require a wye fitting.
  5. hoopers2
    hoopers2 New Member
    Nov 6, 2012
    Texas
    Thanks! :D
  6. hj
    HEre, you CANNOT connect a drain to a cleanout riser. But the type of cleanout fitting in the ground would determine whether it would be a good idea for you to do it even if it were permitted. IF it is a "two way" cleanout fitting" then you CANNOT connect to it. If it is a "Y" or combo then it will work.
Similar Threads: Connecting outside
Plumbing Forum, Professional & DIY Advice Connecting Sch 40 PCV to outside SDR-35 sewer line Aug 16, 2014
Plumbing Forum, Professional & DIY Advice Connecting L copper to M copper Mar 11, 2017
Plumbing Forum, Professional & DIY Advice Connecting new shower drain to existing tub drain Mar 5, 2017
Plumbing Forum, Professional & DIY Advice Connecting additional shower drain to an existing tub drain. Feb 28, 2017
Plumbing Forum, Professional & DIY Advice Weird thing with flushomatic toilet; tube connecting pipe to wall Aug 30, 2016
