Cold Water in Tub/Shower Diminishing. Please Help
Discussion in 'Shower & Bathtub Forum & Blog' started by cpg13, Jul 31, 2013.
  1. cpg13
    cpg13 New Member
    Jul 31, 2013
    Washington, DC
    Hello,
    I have a combo bath & shower with a double handle faucet, similar to this one (http://www.homedepot.com/p/Glacier-...ome-833-0401/100662005?N=1z11e3f#.UflO7I3VCDo)
    Back in October on 2012 I had some work done in the bathroom to replace all the pipes with copper pipes and the water pressure in the tub and sink was great. Recently (past few weeks) the cold water in the tub has diminished to a small trickle and the hot water seems to be much hotter (maybe this is just because I have no cold water?). The cold and hot water in the sink is fine.
    Does anyone have any suggestions on how to fix this? I would prefer to do it myself if I could, I am just uncertain where to start.
    Thanks You!
  2. jadnashua
    The pressure balance spool valve may be partially stuck. Some debris in the line may be all it is. On some designs, that is built into the cartridge, on others, it's a separate, replaceable assembly. Or, it could be inlet filter screens that are clogged. You could turn the water off, take the cartridge out, then turn the water back on momentarily - it might flush things out.
  4. Terry
    Aug 17, 2004
    I would pull the stem out of the cold side of your two handle valve and see if it needs cleaning.
    Make sure the main water supply is off first.
  5. cpg13
    cpg13 New Member
    Jul 31, 2013
    Washington, DC
    Thanks! I will give it a try :)
  6. hj
    quote; The pressure balance spool valve may be partially stuck.
    Two handle faucets do NOT have a pressure balancing spool and most of the rest of the posting applies to single handle faucets also. If only the cold water is affected, the cause is probably in the faucet itself, but if not , the you could have a major problem.
  7. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    How do suppose they can claim "This fixture is built to maintain a constant temperature for a safe and comfortable shower experience." and "Designed to maintain a constant water temperature to prevent accidental scalding"? There is nothing I can see in the IPL that supports those claims.
    http://www.homedepot.com/catalog/pdfImages/ae/ae3481de-d133-449c-8a26-497fc6771e7f.pdf
Similar Threads: Cold Water
Shower & Bathtub Forum & Blog Cold, hot water lines to new bathroom Wednesday at 5:54 PM
Shower & Bathtub Forum & Blog shower not mixing enough cold water Apr 11, 2015
Shower & Bathtub Forum & Blog Shipping Shower Waterproofing in cold weather: How to protect from freezing Oct 17, 2014
Shower & Bathtub Forum & Blog Hot water reduced to trickle in shower - cold water works fine Jun 24, 2014
Shower & Bathtub Forum & Blog No cold water in shower Jun 1, 2014
