Charlotte trap union won't seal
maintenance man
Kingsport, Tennessee
I have a 2" trap (Charlotte brand from Lowes) and the threaded union on it keeps dripping no matter how tight I get it. It is just a "V" shape at the end of the threads that is supposed to make the seal, no O-ring or anything else. I have bought two now with the same results. What can I do? Could I just PVC glue it and then just thread it back together? Anyone else having this same problem?
WorthFlorida
Solutions
Orlando, Florida
No glue please. Not sure why it's not sealing but it is assumed that it is leaking from the so called "V". Before you get desperate and use use pipe dope that makes a mess, try a little teflon tape wrapped around the "V". If you want to glue get the trap made for glue, L0wes item #: 23437 .
maintenance man
Ok thanks guys, I ended up putting a bead of Leak Lock in the chevron style sealing portion of the Union. It worked good, but next time I will avoid the trap with a screw type Union.
