Tom S
Hello,
I own a 102 year old home that has its original cast iron drain pipe. After a shower on the top floor the basement flooded and there were water streaks running down the drain line. (Photos below)
I created an access in the floor outside the bathroom and found the culprit - the cast iron elbow at the top of the stack failed.
I’m not a plumber, but I’m handy and not afraid to take on a project. Do you recommend I call a professional for this repair? Or is it something I should try?
I'm thinking to rent a snap cutter to cut on the outside of the elbows hub and just under the stack's hub. Then replace the cast iron elbow with ABS and neoprene shielded couplings.
I appreciate any advice!
