cast iron closet flange leaded into pvc
can I remove a leaded cast iron flange from pvc pipe in the same manner as usual
  • yes
    Votes: 1 100.0%
  • no
    Votes: 0 0.0%
  • Total voters
timbo0876
I have a cast iron flange on my Toilet and it is leaded into a pvc I want to drill the lead out and break the flange ring..My concern having never seen this is well it be possible to re use the pvc pipe or should I plan on busting up the concrete to make repairs
timbo0876
The ring is severely rusted and I want to retile the floor and I don't think a repair ring and spacer would be a proper repair
Tom Sawyer
Maine
It's one of those won't know until you try things but yes, drill the lead out
Smooky
North Carolina
Are you sure it is leaded onto the PVC? That seems rather unlikely since lead has a higher melting point than PVC pipe. Maybe it is some type of compression flange.
Asktom
Victor, MT
The cast iron will absorb the heat before the plastic melts, at least it does when caulking plastic pipe into a cast iron hub - I never tried a closet ring, which has less mass. However, plastic pipe has a larger OD than cast iron and I don't see how the ring could fit over it unless the ring had been modified.
timbo0876
Yes it's definitely leaded into the pvc I cleaned up all the grime and wax and sure enough it's lead
Cast iron not only does NOT absorb the heat, but it holds it for a long time after the lead is poured. Cast iron rings/flanges ALL are rusty, but that has nothing to do with them needing to be changed. If you drill the lead, you will probably damage the PVC and have to change it. Break the flange and then just slide the lead off the PVC.
Tom Sawyer
Maine
The PVC is not going to be usable anyway whether you break the flange or drill the lead. Unless there's room for a Fernco the PVC will be partially melted and too rough to glue another flange to.
If the PVC is 4 inch, and the leaded flange is on the outside, then a flange, with a metal rin that fits to the inside of the 4-inch PVC could be an easy option. They even make closet flanges to go inside 3 inch PVC, but those are not so well regarded.
timbo0876
Yes the cast iron flange is on the outside of the pvc. It also looks like when they made the up turn with the elbow and used a short piece of pvc pipe I could cut that out and just glue another in it's stead
ALL cast iron flanges are "rusty", but that in way way means they have to be replaced. I replace them when they are cracked, and ONLY if they are cracked.
