Jgad60
Oh, that is awesome! So basically I'll just need to figure out a way to lower the two top bolts down then, I think I'll go ahead and give this a try.
One more question, the Case 3000 had a sort of fabric like material where the toilet met the drain where like the wax ring goes on a floor mounted toilet. Is there anything different about a wall mount where something similar to that is needed for replacement or would I just need to get a new wax ring to replace that with the new toilet?
Thanks again!
Did anyone answer you about what goes between the Case 3000 toilet and the drain pipe. I have two 50 year old Case 3000s in a seldom used vacation home which recently started leaking. The only thing I can figure out is a dried up/leaking seal when the water leaves the toilet. I have not taken either one off the wall yet.
