Can one wet vent, vent a toilet sink and tub. if so show me a drawing
Venting the toilet with 2", and with that 2" vent, pull off the tub, and above that, the lav.
This drawing shows either, but I have also plumbed both the lav and the tub off of the W/C vent and that is code.
You can vent the bathroom with one 2" vent.
It stacks like this, toilet on the bottom, then tub, then lav.
You can go 42" on a 1.5" trap arm to the tub and also to the lav.
Or this on the horizontal works too.
Tom Sawyer
Maine
Under the IPC you can wet vent two bath groups off a single 1-1/2" vent
Under the IPC, you can do almost anything you want to, and if it is not permitted, you just make an application for change and it will be added to the code. But, I am sure even the IPC has some limitations on HOW the piping has to be arranged so two groups can use one "wet vent".
WJcandee
Wise One
New York, NY
What's even more concerning is HOW the IPC permits you to do this. Having tried hard to learn the "right" (meaning guaranteed-effective) way to vent stuff, I am bewildered by what the IPC now says is an adequate arrangement to vent two entire bath groups, including WCs. WHERE the vent can be connected makes no sense to me. (This came up and was discussed in another thread.)
Tom Sawyer
Maine
Why not? Just how much ventilation do you think it takes to vent essentially a single 3" drain? Most times both bath groups will be sharing a single 3" drain and most codes say you need a vent that is half the size of the horizontal drain. When you look at the numbers, a single 1-1/2" vent is more than adequate. Toilets don't need vents. They are a full siphoning fixture in which the entire surface area of the bowel is effectively the vent. Codes that still require a separate toilet vent are grossly outdated.
Revcbt
Idaho
Well said. I clicked into this convo because the title caught my interest related to a job I did a few years back. A few years ago I plumbed a shower, laundry, sink, w/c and lavatory on a single 1.5 vent 3" waste. I reviewed IBC repetedly to ensure I wasn't risking a major problem and didnt see any reason I couldn't. 2 years later with heavy use no problems, I discovered the roof vent had never been uncapped. Shocked, I put it through a series of tests and the shower trap and toilet would tidal a bit but thats all.
