I have two Toto toilets with GMAX valves. Both have always worked fine except it seems that the water level in the bowl after the flush sems to be too low.
There is a rim or ledge in the bottom of the bowl that appears to be where the top surface of the water should be. But the water level is considerably lower than that, which results in more residue sticking to the sides of the bowl in that area.
It is as if the bowl does not fill properly.
Inside the tank, the water level reaches to about 1/4" from the top of the overflow, so the tank filling seems ok. Holding the lever down so that all of the water leaves the tank into the bowl does not help.
Any advice?
Any advice?
