Bathroom Options
Discussion in 'Remodel Forum & Blog' started by jerome8283, May 28, 2008.
  1. jerome8283
    jerome8283 New Member
    Oct 4, 2006
    New York
    I'm tiling my bathroom and have a small area that separates the toilet area from the rest of the bathroom. There's a small wall near the shower that often gets a little wet due to the closeness to the shower. You can see the damage near the bottom. I attached pictures..
    What could I do with this? Tile? Greenboard? Can I tile over drywall?
  2. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    There are a couple of things you can do.
    1) They sell these glue on dividers that you can mount on the ledge of the tub. Think the hypotenuse of a triangle. This blocks water from exiting the shower enclosure. They are cheap maybe $15. Go on with glue and caulked for appearance.
    2) You can tile but you'll have to replace the drywall with cement backer board. The drywall won't hold up and grout is porous.
    3) You can glue up some synthetic paneling. You'll have to ensure a good fit and caulk with 100% silicon. It won't look good but it will work.
    Tom
  4. CharlieM
    CharlieM New Member
    Jul 1, 2006
    Iowa
    First you would have to replace any damaged drywall.
    After that, you could use a product called Kerid-band (thin waterproof membrane) that is thinsetted to the drywall, then tile over that.
    Charlie
  5. jadnashua
    It is very common to bring the tiled area out beyond the tub one row to help with this kind of a problem. It can be worse if the tub is no longer (or never was!) level.
  6. jerome8283
    Oct 4, 2006
    New York
    Hi Jadnashua, I'm not following your point.
  7. Terry
    Aug 17, 2004
    It's common to have backer board over the tub, and drywall after that.
    for the little bit between the tub and the corner, tile would be fine.
  8. jadnashua
    It wouldn't be unusual to tile that small bit outside of the tub, then spray wouldn't be an issue - i.e., an extra row of tile.
  9. jerome8283
    Oct 4, 2006
    New York
    Should I go half way up the wall? I'm also a little concerned about where the wall meets the shower enclosure and how tile would look.
  10. CharlieM
    CharlieM New Member
    Jul 1, 2006
    Iowa
    If I were going to tile something like this, I would find a bullnose tile that looked nice with the tub/bathroom and cut/install it as a border around the whole thing. Leave an 1/8" gap between the tile and the tub/surround, then caulk that with silicone.
  11. jadnashua
  12. jerome8283
    Oct 4, 2006
    New York
    I'm a member there as well. I will try posting. Thx
  13. topak
    topak Guest
    this what i'm thinking...
    i am not a pro in the said criteria.,so i could only suggest that you seek advice to the experts in the said field, about kitchen remodeling. :rolleyes:
  14. jerome8283
    Oct 4, 2006
    New York
    Do they have a forum? :rolleyes:
Similar Threads: Bathroom Options
Remodel Forum & Blog Basement Bathroom Flooring options Mar 7, 2010
Remodel Forum & Blog Bathroom vent fan discharge options Feb 26, 2005
Remodel Forum & Blog Bathroom subfloor 1/2" MDO plywood adhesive? Sunday at 1:38 PM
Remodel Forum & Blog Tiny bathroom remodel Aug 28, 2016
Remodel Forum & Blog Bathroom subfloor question Aug 11, 2016
