Bathroom H/C supply question.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by beachfront71, Jan 16, 2011.
  1. beachfront71
    beachfront71 New Member
    Jan 15, 2011
    newport beach, ca
    Hello and thanks. We are turning a bedroom into a bath and it is located at one end of the house away from all the other plumbing fixtures (kitchen, other baths, etc.)
    There was an older radiant heating unit in this room and which had 1/2 Hot and Cold copper running to it but was hooked up to a solar water heater that is no longer here.
    The location of this pipe is almost perfect and I am wondering how many fixtures I could run off of this (if any) knowing that the nearest 3/4 line is a good 20 feet away.
    The bathroom will have 2 sinks, tub, toilet, and shower w 3 seperate valves..
    Is it feasable to use this pipe or should I scrap it all together and just have new pipes run with the drains..
    Again, appreciate the feedback
  2. hj
    If you do not mind having "very poor volume" in the new bath use those lines, otherwise replace them.
  4. Terry
    Aug 17, 2004
    I also don't believe you can use heating pipes for potable water. Any inspector would want to see new pipes for new water.
    It spells that out in the code book.
    For what you plan, 3/4" pipe, and only two fixtures on 1/2"
Similar Threads: Bathroom supply
Plumbing Forum, Professional & DIY Advice Moving bathroom sink water supply lines Mar 14, 2017
Plumbing Forum, Professional & DIY Advice Off center water supply line for bathroom faucet Feb 15, 2016
Plumbing Forum, Professional & DIY Advice Bathroom Faucet Supply Line and Valve Size? Jan 16, 2016
Plumbing Forum, Professional & DIY Advice Bends in Bathroom Faucet Supply Line Jul 8, 2015
Plumbing Forum, Professional & DIY Advice Bathroom drain and supply Lines Jun 22, 2014
