Air Testing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nelsonba, Oct 16, 2007.
  1. nelsonba
    nelsonba Member
    Sep 28, 2005
    Minnesota
    Does anyone know of an online supply store that carries air testing equipment for DWV systems? I'm planning to test on the 1 1/2" sink drain, but don't have any of the equipement needed.
    Thanks,
    Barry
  2. got_nailed
    got_nailed DIY Senior Member
    Jan 11, 2006
    I just reduce it down till I can get a 1/2 brass T into. One side into the plumbing, one side to a shredder valve, and the one side to a PSI gage.
  4. nelsonba
    nelsonba Member
    Sep 28, 2005
    Minnesota
    Are the shredder valves and gauges available at big box stores, or would I need to go to a plumbing supply store?
  5. got_nailed
    Jan 11, 2006
    Sometimes it is hard to find the shredder valves. But yes you should be able to find them in the big box store.
    If you use a on off valve you can use a quick disconnect fitting right into your compressor. Just turn the presser down to about 5 over where you want it before you start.
  6. jadnashua
    Try Schrader valve (similar to the one on your tire). I never looked for one, so can't help where to buy one with a threaded connection.
  7. hj
    gauge
    find a store that has a 15psi gas testing gauge. It will have everything already assembled including the Schrader valve.
Similar Threads: Testing
Plumbing Forum, Professional & DIY Advice Testing plumbing with air, flux in pipes... Dec 27, 2016
Plumbing Forum, Professional & DIY Advice Air pressure testing water lines Nov 10, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing copper pipes Sep 24, 2016
Plumbing Forum, Professional & DIY Advice Testing a copper line Sep 3, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing PEX lines leading away from a ManaBloc? Feb 23, 2016
