air test vs water test
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by web_surfer, Aug 21, 2009.
  1. web_surfer
    web_surfer New Member
    Jun 8, 2009
    insurance
    Wisconsin
    Now that the plumber is gone & I have finished the laundry hookups we are ready for the city plumbing inspector to come through next week. When talked to him on the phone I told him that we (me & plumber) would do an air pressure test @ 80lb; however he said it really wasn't necessary, that just doing test with water on would be fine. The plumber said he preferred an air pressure test and would come back to do it.
    So my question is, other than having to drain water if there is a leak, are there any other advantages of an air pressure test over water test?
    Thanks,
    Matt
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Air tests are usually tested at a higher PSI (I've seen systems tested at 130-150, your house may have anywhere from 30-80 PSI in the water lines. Less to cleanup if there is a leak with air though.
  4. Terry
    Aug 17, 2004
    In the Winter we used to test with air.
    Nothing like going back and fixing frozen pipes.
    It's also qucker to repair leaks,
    but then if you don't have any leaks, then there is no time being saved.
    Most of the time, we tested with street pressure.
    Sometimes an inspector will want a hydrostatic test.
  5. jadnashua
    If the pipes have never had water through them, it's easier to fix a leak. Sometimes, you could probably just reheat and add a little more solder. But, if it didn't flow well, it may not have been cleaned and prepped well, so taking it apart may be better. If you do a water test, you don't have a choice, you must take it apart, clean, then resolder. that can be a pain if things are tight and you can't spread the pipes enough. My guess is it's probably easier to hear an air leak than maybe spot a drip, but that's just a guess. Course, your hearing has to be good.
  6. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    testing with high pressure can be a safety issue so be careful if you do it that way. I worked on a job where we tested with air because there were a lot of "traps" the way the pipes ran. Pumped the lines with 50lbs of air. one of the plumbers heard a leak but it was hard to tell exactly where it was coming from. He went to feel an elbow and it blew apart, not soldered at all. had to bring him to the hospital for stitches as the pipe whiplashed and caught his hand.
  7. Terry
    Aug 17, 2004
    I was on a large job with lots of plumbers, and the 1/2" caps were blowing off the stubouts like bullets.
    No solder on those either.
    Hey, I didn't solder them. That was the other guys on the job. We had a big crew with the 250 unit.
  8. web_surfer
    Jun 8, 2009
    insurance
    Wisconsin
    The plumber told me it would be easier to fix also if was an air test but, he did not tell me why. He said he would fix any leaks on the work he did (he is very confident there won't be any). Do not feel right asking him to fix leaks on the plumbing I did. So now I am curious as to the mechanics of fixing a leak found via air test if one does occur in the laundry area plumbing that I did?
    Thanks,
    Matt
  9. web_surfer
    Jun 8, 2009
    insurance
    Wisconsin
    air test done
    Ok, did air test and pumped it up to 80 psi. Evidently there is a slow leak somewhere since lost 4psi in 13 minutes on the pressure test of the whole system. Then when did test on just section between meter shutoff and the ball valve inserted in new supply line after meter, lost like 4psi in about 4 minutes. The pressure gauge is in between meter shutoff & new ball valve. Weird losing more psi quicker on just the small section (4') vs whole system.
    So now get to start the fun process of figuring out location of leak(s). There is a small leak from water meter even though water is off. The city inspector said water pressure in city is around 50psi. Is it possible that the much higher 80psi test pressure is going back through the meter into the line through the known slow water leak from meter shutoff valve (old turn handle style).
    Figured I would start with valves first - have total of 15 Nibco ball valves in system - maybe the nut on control stem needs to be tightened on one or two. Obviously I am hoping it is something relatively simple.
    Any special solution, other soap/water mixture, used to test joints, etc. for leaks?
    Thanks,
    Matt
Similar Threads: test water
Plumbing Forum, Professional & DIY Advice How to pressure test new water lines? Nov 14, 2016
Plumbing Forum, Professional & DIY Advice Air pressure testing water lines Nov 10, 2016
Plumbing Forum, Professional & DIY Advice Water Treatment Advice Needed (See test results inside) Jun 17, 2016
Plumbing Forum, Professional & DIY Advice Humidifier, testing water flow Sep 23, 2015
Plumbing Forum, Professional & DIY Advice water pressure test result questons Sep 26, 2014
