Advice on well pump set up.
Limitless
California
Hi all,
My wife and I recently purchased 20 acres in Temecula California to retire. The land has an 800' well with liner no pump no house/mobile home yet. Sadly it's a slow yielding well at 1.5 GPM's. I'm leaning towards a 3hp pump approximately 700' feet down, a booster to a 5000 gallon reservoir. What do you guy's think about solar? I get good sunlight in Temecula California. With the crazy inflation we are working with a tight budget, and love the idea of doing most everything ourselfs. What brands do you guy's recommend? I am looking for quality and affordability. I appreciate all the help I can get.
You will want something to shut down the pump for a while if the well runs dry.
I don't know about solar for the pump, but if you have commercial power available, I suspect you will be better off using that money for something that can feed power back to the power grid.
I would be thinking a 1.5 HP 3-wire 5 gpm pump, such as the Grundfos 5S15-31 When you see a pump advertised just as a 3 HP pump, that may not be strong enough to lift your water.
Limitless
California
Thank you Reach4 for the reply. I have heard lots of good about the Grundfos pumps, and will definitely consider one. I'll look into a system that will shut off when wayer level is too slow to avoid obvious damage.
