Acid Neutralizer suggestions
Discussion in 'Water Softener Forum, problems, installation and r' started by RWL, Mar 10, 2012.
  1. RWL
    RWL New Member
    Mar 7, 2012
    Central PA
    Our water's pH is 5.5 so I need an acid neutralizer. Our experience with our dying current conditioner is that we need the calcite - corrosex mix to neutralize the acidity. A flow test by the Culligan rep showed a flow rate of 8.4 gal / min. Two adults live here and there are 2.5 baths. The pipe coming off of the well tank is 3/4", but the rest of the distribution system in the house is 1/2". I've read enough in the forum that I decided to get a downflow (one that has a back flushing valve) system.
    How much calcite / tank size? I'm guessing 1.5 cu ft.
    I'm inclined to go with the newer Fleck 7000 series valve based on dittohead's description of this valve (for softeners) in another post. My question is, which 7000 valve? If I've misinterpreted some of the other threads and the 7000 series valve really isn't a good choice for a neutralizer, explain why, and what's a better choice?
    Anything else I need to specify, or look out for?
    What is the maximum number of days between backflushes on an acid neutralizer?
    Who on the web has good prices and service for this?
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Not sure if straight calcit will be enough, one might need some magoxide to help out in bringing up the 5.5 ph to above 7.0
    As for backwashing there is no hard and fast rule , but the more the better in keeping any bed from forming channels and going hard in one large block.
  4. RWL
    RWL New Member
    Mar 7, 2012
    Central PA
    Any feeling on the cubic foot size of the neutralizer I need? Is the Fleck 7000 a good choice for this?
  5. Superplum
    Superplum Licensed Plumber
    Apr 11, 2012
    Plumbing & Heating Contractor
    Putnam County, NY
    To repeat another thread, I think you should address the PH problem as a whole. Low Ph can be a bigger problem then hardness. Didn't you get a water test before installing a softener? A softener won't raise the PH. If you don't have too high of a TDS (total dissolved solids) you can use a Calcite type of neutralizer. If the TDS is too high it will diminish the ability of the water to absorb the Calcite. Then you should use a chemical feed pump injecting a soda ash solution into a 40 gallon retention tank (preferably before the well tank). If you can use a calcite unit, which is lass troublesome (IMO) it would go after the well tank but before the softener. Make sure you order one with a dome plug to fill the Calcite. Believe it or not I have a competitor in my area who has installed at least 2 without the dome hole in the tank. I have to remove the entire head to add Neutralizer. A Master NS 20 combo unit would have been a great choice if you didn't already have a softener (depending on TDS)
    I don't know if you have a softener yet like this other guy, but I thought this would be helpful. Master has used Autotrol heads for decades but has recently started using Clack heads, I believe you can order it with any head you want. They also sell a non backwashing upflow unit which is less money & doesn't require electric or a drain. These are not for every situation though & you need to have a sediment filter ahead of it since it can't remove dirt.
  6. ditttohead
    Jan 9, 2012
    Ontario California
    I agree with the domehole, but... many of the dealers we sell to do not use the dome hole. They simply pop the head off, add calcite as needed, and put the head back on. It only takes a minute to remove the head, and their reason for doing it this way was that filling through the larger 2-1/2" opening is simpler than filling through the dome port. Either way is correct. I prefer the dome holes and Pentairs/Structural new design is much better and less troublesome than previous dome hole designs.
    Now for upflow acid neutralization, I really like the Clack 1190 in-out head with the fill port built into the head itself. No need for a dome hole with that head.
    Upflow can be very effective, I prefer it when it can be done correctly. Like you said, proper filtration prior to the calcite is important. The majority of upflow calcite systems we sell are for equipment where the flow rates and water quality are known, and consistent. A downflow calcite system is a safer bet when these factors have variances.
  7. Gary Slusser
    Retired
    Most homeowners should not use upflow AN filters. Upflow requires a prefilter and most people use a disposable cartridge filter and they don't change the cartridge based on pressure loss as they should, they use calendar time or how it looks. That causes a flow reduction and possibly changeling of the AN mineral and insufficient neutralization.
    Downflow/backwashed it the best way to neutralize acidic water.
  8. chevy427
    chevy427 Banned
    Nov 20, 2010
    USA
    Are you recommending an Upflow AN system before or after the pressure tank?
  9. Superplum
    Apr 11, 2012
    Putnam County, NY
    If you meant me Water Solutions, it would have to go after the pressure tank. I didn't say I would definitely use an upflow, only that it was an option. Unless he is starting out with a near zero hardness, than a softener should also be used (after the neutralizer) since he is raising the hardness. If that is the case then a back washing combo unit would be a better choice. It would have one head for both neutralization & softening. For that reason there is only one backwash for both saving incoming water, with less water going to drain (maybe septic) & one head to service.
    If he has a high TDS, he may need a chemical feed pump injecting a soda ash solution into a retention tank to reach 7.0 PH. That [/II would install before the pressure tank to protect the tank & control tee from the low PH water. This would not obstruct the water flow as the others units mentioned could (possibly causing very high pressure & damage).
    As far as having to remove the heads to add neutralizer, this usually takes two guys (one to hold the tank & one to spin the head). Both of the units I service this way have Fleck heads which require removing the screws on the hold down clips every time & pulling the unit out where you can spin the head. One of them has a stripped out screw hole in the head from repeatedly removing & re installing it. I have a self tapping screw in it for now. Eventually the whole head will need replacement as a result. A dome hole is much easier. I use a stick ruler to settle the bed & push the new powder to the other side making it close to level. ]
  10. ditttohead
    Jan 9, 2012
    Ontario California
    I am recommending downflow, but many people see the upflow price and decide to go that way. Upflow is great, but only when the water quality and flow are consistent. Post whole house RO, acid neutralizer for industrial applications, remineralizer for a water store, etc. are common applications where upflow can work well, Not really ideal for this application.
  11. Gary Slusser
    Retired
    No I'm not.
    DIYers, do not install an type of filter between a well pump and its pressure switch. Or anything else that can block up preventing the switch from seeing the pressure increase in real time or you run the risk of damaging the pump, the filter housing or the plumbing.
  12. Gary Slusser
    Retired
    DIYers, any time you use a sacrificial mineral filter to neutralize acidic water, you will add some hardness to the water. Usually not more than 4-8 gpg.
    Any type combo unit (tank over tank) is very difficult to work on if you need to replace mineral or resin. And to backwash mineral you need high gpm, that may damage resin in the softener part by wearing down the beads due to friction. The combo being mentioned is the Master Water Treatment brand and is only sold through plumbers and well drillers and they purchase it from their supply houses; it is not sold online.
    IMO a separate backwashed type of filter, mixed bed [< 6.0 pH] or regular mineral [=> 6.0 pH] is much better than an an UPflow filter or solution feeder and retention tank.
    Captive air/bladder type pressure tanks do not need protecting from acidic or any other type water because they have an internal epoxy coating and impervious 'bladder'. Non glass lined galvanized tanks don't have that protection.
  13. chevy427
    chevy427 Banned
    Nov 20, 2010
    USA
    I agree not to install any type of filter before the pressure switch. An upflow AN, however, is not a filter and there are applications where this is alright and even preferred.
  14. Gary Slusser
    Retired
    So you are saying an UPflow AN something can't block up. I know they can. Also, the prefilter for the AN something can also. That's some pretty bad advice IMO.
    Nothing that can block up should be installed between a well pump and its pressure switch.
  15. chevy427
    chevy427 Banned
    Nov 20, 2010
    USA
    I think you missed it. I said I would never put a filter before the pressure switch. I don't recall saying anything about a prefilter. Not sure why you didn't get that.
    No, an AN upflow Calcite system will not block up under normal circumstances and applications. I have never had any of my customers have this problem or anything approaching this problem. All of my personal follow-ups actually show that it works very well. This position actually provides the most thorough expansion of neutralizer tanks and avoids channelling. It is not used in all cases but is very effective
  16. Superplum
    Apr 11, 2012
    Putnam County, NY
    Captive air/bladder tanks usually have a galvanized steel inlet elbow on the bottom. This is where they tend to get pin holes when subjected to corrosive water. If the tank is under warranty, it will be covered since the elbow is considered part of the tank. Of course you still have to change the tank. I have never been able to replace one of these elbows without damaging the bladder. You still have to remove the tank & lay it down to try. The control tee, check valve, & all the other components are brass. Brass is highly sensitive to corrosion. Despite all that I still would not install an up flow, down flow, softener, cartridge filter, shut off valve or anything else that could restrict the flow before the pressure tank/pressure switch. Only a retention tank if needed would be suitable for this location. For those who don,t know, a retention tank is only a water tank piped so as not to retain air (in the bottom out the top usually) with an injector fitting on the incoming pipe. I use fiberglass tanks with plastic pipe for this as it stands up to corrosion.
  17. Superplum
    Apr 11, 2012
    Putnam County, NY
    The first part of my post wound up within Gary s quote for some reason;
    So if you start out with 4-8 gpg you wind up with 8-16gpg & should use a softener.
    You commented on a 20 year old Master NS-10 combo unit in another thread. It had a brine draw problem (simple to fix) & now it's working fine. I have units out there older than that & have not had the problems you're talking about. What's wrong with a DYIer buying from a local supplier and doing his own installation? Where will he be buying the 50lb box's of NS mix (calcium & Magnesium) or calcite to service it, online? How much is shipping on that item? I have seen other makes of combo units sold online for those who think online is the only way to shop.
    I agree for the solution feeder/retention tank, when a neutral PH can achieved this way. If not (usually due to high TDS) they will still be getting blue/green stains & corrosion. What do you tell them then?
  18. Gary Slusser
    Retired
    I did well pump and pressure tank service for many years in PA where we had very acidic water. I do not recall that I ever saw an elbow on a pressure tank leaking due to pin holes. The tanks I sold had SS elbows. I don't think I ever replaced an tank elbow but I replaced a lot of homemade galvanized 'Tees' with brass. I had 2 24" pipe wrenches and I'd turn the tank upside down in a new tank box to do it.
  19. Gary Slusser
    Retired
    There's nothing wrong with a DIYer buying from a local dealer as long as the dealer will sell them repair parts instead of insisting only they can do the repair. At the same time the price from a local dealer should be much higher than an online dealer even with the shipping because the local dealer has much higher overhead than an online dealer does.
    A combo unit is very difficult to replace resin in and IMO dealing with many DIYers since 1992, most will not be able to do it without problems. I used to sell combo units way back when, I didn't like them because you are combing filtration with softening resin at much different flow rates. And short customers had a tough time reaching the control valve... LOL
  20. chevy427
    chevy427 Banned
    Nov 20, 2010
    USA
    Perhaps you can share how you know this. Was it something you put in or maybe personally serviced. How was the upflow installed and what kind of well pump was used? Shallow well? I would be interested to hear about your experience here.
  21. Gary Slusser
    Retired
    As you know when you are not playing cute... all it takes is anything that can block up the teen tiny slits in the bottom basket. That is why a prefilter is prescribed before an UPflow something. BTW, most people call them an AN filter.
    Some people, mostly plumbers and drillers but homeowners too, don't install a prefilter. I've torn them out and replaced them with a backwashed version.
    Tell me, you really don't know how they are plumbed into the plumbing? And... what difference does it make as to what kind of pump, or well, the person has?
Similar Threads: Acid Neutralizer
Water Softener Forum, problems, installation and r Draining Softener and Acid Neutralizer to Outside Saturday at 11:49 AM
Water Softener Forum, problems, installation and r Is it safe to run chlorine water into acid neutralizer from well shock treatment? May 21, 2013
Water Softener Forum, problems, installation and r Low water pressure from water coming out of acid neutralizer. Bypass pressure is OK May 19, 2013
Water Softener Forum, problems, installation and r Recommendations on Acid Neutralizers Dec 10, 2012
Water Softener Forum, problems, installation and r Please help with acid neutralizer questions Apr 6, 2012
