4" closet bend or 3" street 90?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by remodelbob, Jan 11, 2008.
  1. remodelbob
    remodelbob New Member
    Jun 30, 2005
    Washington
    I am trying to install a toilet waste line in a 2x10 joist bay. My horizontal run is pretty long (almost 20' fortunately goes into a dropped ceiling area near the end, so I will have enough slope), so I need to keep the 3" pipe tucked up as high as I can near the toilet. I was planning on using a 3" street 90, but my plumbing reference book keeps mentioning a 4" closet bend.
    When I look at a 4" closet bend it looks like it would do a much better job of moving the waste, but it is also much deeper than the 3" street 90, which means I am not going to be able to meet slope requirements.
    Is the 3" street 90 adequate? or do I need to find an alternate plan?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I'm not a pro, but I'm pretty sure the 3" will be fine. Have you planned the vent?
  4. remodelbob
    Jun 30, 2005
    Washington
    yup, breaking off with a 3x3x2 Y.
  5. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    3" is fine for a bathroom. I would use it for that.
  6. construct30
    construct30 New Member
    Jun 16, 2007
    NorthWest PA
    Straight up or 45 degree or more.
    How do you guys make these darn computers make a degree sign?
  7. remodelbob
    Jun 30, 2005
    Washington
    not enough room to go straight up. going 45 degrees.
  8. construct30
    Jun 16, 2007
    NorthWest PA
    That's OK, I take it you can't make a degree sign either.
    They must type it first then post it?
  9. hj
    bend
    Uses the spigot closet bend. you can cut the riser off at the floor line after the tiling is complete. It will be "shorter" than a 3" street elbow, just be sure to have enough of the spigot below the floor level so the closet collar/flange will slide down to the floor.
  10. Terry
    Aug 17, 2004
    Like hj, I also use a closet bend for that reason.
    The local hardware stores carry an ABS 4x3 spigot closet bend that will take a 4" closet flange.
    If I really want to make it tight, I can trim a bit of closet flange hub away to let the flange drop down farther.
  11. BAPlumber
    BAPlumber Plumber
    Jul 18, 2007
    Journeyman Plumber, business owner
    Vashon, Washington
    one option would be to use a 45 degree closet flange and a street 45. that would keep you pretty high.
Similar Threads: closet bend
Plumbing Forum, Professional & DIY Advice leak testing new closet bend Feb 5, 2015
Plumbing Forum, Professional & DIY Advice Trim Closet Bend? Nov 8, 2014
Plumbing Forum, Professional & DIY Advice Repairing lead bend closet flange. Oct 10, 2014
Plumbing Forum, Professional & DIY Advice 4" inside offset toilet flange that fits completely inside closet bend? Sep 2, 2014
Plumbing Forum, Professional & DIY Advice Oval shaped lead closet bend??? Dec 5, 2013
