I have done a lot of searching for this issue, but none of the threads I can find seem to have this particular question
I have 1 well, a small cabin 75 feet away, and my sometimes home is maybe 150 feet from the well, I would like to run the water lines to the houses so that I can have both houses work with their own pressure tanks, but also be able to drain the water from either building and the other house still have water, what's the best way to set this up so that I don't have cycling problems with the pump.
I would like to be able to leave for weeks at a time without having to heat one of the buildings, but it won't always be the same one I need to drain and shut down
So 2 houses, 1 well, and I want them to both work independently without relying on the other house for pressure, is this possible?
