Brad Perkins
Today I have a question about float switches again. My plan is 2 normally closed switches with a 13 amp continuous rating. One is primary and other is secondary. I'll use the same switch on a normally open configuration for projecting my cistern pump in the event it tries to pump the tank dry. I also want to incorporate a float to activate a siren if the primary float fails.
Now the question. Should the pump switches be wired directly to the pump or through a relay? What is the max amperage I should expect to see from a Goulds 1/2 hp 10 gpm pump?
